diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   Can you gentlemen help me design a Zobel circuit? (http://www.diyaudio.com/forums/multi-way/190943-gentlemen-help-design-zobel-circuit.html)
Broadwayautoclinic 16th June 2011 05:03 AM
Here is what I got... Luckily I can always return it :-)
I am replacing the crossover and drivers in my Mission speakers. I have purchased the Dayton 8" series II woofers for the task. They have an L(e) rating of 1.3 They will be wired in parallel. http://www.parts-express.com/images/.../295-100_s.jpg
http://www.daytonaudio.com/lspeakers...-8_295-100.pdf
I am replacing the Dome tweeter with a full size Heil, crossed over @ 2000HZ. I have purchaced the Dayton 2 way crossover as well. I know it's not going to be perfect out of the box. I will be adding a 4 ohm 10 watt resistor to the positive lead of the Heil to raise the impedance to 8 ohms and take it down a few decibels, which is what the Dayton crossover tweeter output is rated at. The woofer output is adjustable ( 4 or 8 Ohms) , and I am selecting 4 ohms. I am potentially adding a L pad to the circuit as well between the crossover and the Heil to adjust the output of the Heil.
http://www.parts-express.com/images/.../260-140_s.jpg
I want to add a Zobel circuit on the woofer circuit to flatten things out. I am not sure how wiring two speakers together in parallel effect L(e), so I don't know how to calculate it. Can you guys lend me some advice.
Thanks,
Rick
Broadwayautoclinic 16th June 2011 06:52 PM
Anyone?
Loren42 16th June 2011 08:26 PM
Originally Posted by Broadwayautoclinic (http://www.diyaudio.com/forums/multi-way/190943-gentlemen-help-design-zobel-circuit-post2608280.html#post2608280)
Anyone?
Well, with the Dayton crossover you are essentially putting a Ford Fiesta engine into a BMW body. It will be a waste of time and money.
It is a good idea to return it and do your own.
Let's start over, but please read this link first and then you will be much better armed to get to where you want to be.
Everything you need to know about making a crossover is right there. Well, at least the basics.
I don't know what will happen with your intended driver selection. You can model it in some of the free programs or even some of the more expensive programs, but it won't give you very good results. You need to test those speakers and get the T/S constants yourself, first. Then you can intelligently design a crossover that gets the value out of the Heil AMT and the woofer.
DrDyna 16th June 2011 08:29 PM
Don't you still have the ESS crossover with the good air core inductors?
bjorno 16th June 2011 08:45 PM
1 Attachment(s)
Anyone?
Test with a 3.45Ohm resistor in series with a 56 uF capacitor in parallel with your 2 paralleled Dayton 210-8 drivers.
b:)
Broadwayautoclinic 16th June 2011 10:04 PM
Originally Posted by DrDyna (http://www.diyaudio.com/forums/multi-way/190943-gentlemen-help-design-zobel-circuit-post2608416.html#post2608416)
Ya, they didn't sound too good. I have a set of 1A and 1D crossovers. All in great condition. But they didn't mate up with my drivers. Sounded nasally and too bright
Resources saved on this page: MySQL 18.75%
