Old 16th June 2011, 02:21 AM   #1
percy is offline percy  United States
Default Speaker Workshop runs slower on faster cpu ?
I am running SW on 3 PCs. One is an old Athlon single core of the 266MHZ FSB era, a Core2Duo T5870 laptop and another PC with an i7 processor.
The core2duo laptop and i7 both run Win7, the old athlon runs XP.
When calculating crossover responses SW zips through even a complex crossover on the old athlon as well as the new i7, but it crawls on the Core2Duo laptop. Why might that be so ? Is there some arithmetic operation or instruction set thats not in the core2duo that exists in the other two cpus ? Highly unlikely but I cant think of anything else. I have tried putting the laptop in full performance (no power management) mode and it still does that.
I haven't found the laptop to be slow while doing other things and I believe a benchmark score was also close the expected for this cpu.
So what do you think might be going on ?
Old 16th June 2011, 02:56 AM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
perhaps a win 7 issue? compatibility mode?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 16th June 2011, 05:26 AM   #3
Jay is offline Jay  Indonesia
How about memory (laptops usually have smaller memory)? You have to save your work in order to free the buffer (if you do a lot of change but not save it yet, you will run out of memory). In each computer, check the memory usage (by SpkrWork.exe) with Windows task manager (CTRL-ALT-DEL)
Old 16th June 2011, 06:27 AM   #4
AllenB is offline AllenB  Australia
Laptops are typically slower than desktops. They need to produce less heat and consume less power so there are performance compromises.
Old 16th June 2011, 07:13 AM   #5
Any core2duo laptop is about 2x as fast as an old Athlon.
This has to be a software problem.
Speaker Workshop has not been maintained in the multi-core era
Old 16th June 2011, 12:42 PM   #6
I tried running it in compatibility mode as well but no luck.
Memory is good. 2GB out of 3GB is free. Both cores are being utilized as well - about 70/30 split.
The i7 + Win7 configuration blazes through the crossover calculation so I am not sure if its just the raw horsepower of 8 cores masking another problem.
Old 16th June 2011, 06:43 PM   #7
percy, you got thatone right.
win7 does indeed as for now runs few things slower than an older cpu and plain jane win xp.
allso i found that the 64 bit editions can be at some tasks be a lot slower. (whileothers may be faster. it is just a compromise)
just "cuz its neeeaw" it does not at all mean it is absolute better in everything
Re-Jigging the jig: Speaker testing device for Arta, Speaker Workshop & HOLMImpulse MJL21193 Multi-Way 263 9th January 2012 11:24 AM
Speaker workshop ? A_Reef_Scene Multi-Way 14 28th February 2007 12:39 AM
Speaker Workshop, help please Grahamt Multi-Way 5 10th March 2005 11:48 AM
Speaker Workshop do all this? rick57 Multi-Way 8 20th November 2004 02:11 PM
Speaker Workshop: the best and how to use it? rick57 Multi-Way 12 13th August 2004 11:12 PM
Page generated in 0.08763 seconds (78.22% PHP - 21.78% MySQL) with 10 queries
