Hello,
At the risk of sounding a bit dumb... What is the reasonant freq of a TL pipe? Is it the first time the output is out of phase with the driver (assuming you are doing a freq sweep upwards) Or is it when the output of the pipe is greater than the output of the cone? And the cones Fs, is that when it is moving at its most, or at its least? |
#2 | ||
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
But how do I know when this reasonance is?
Say I've a 83cm long tube (inc end correction) which is supposed to be a 100Hz tube, but I dont think it reasonates then at all, there are peaks at 80-90ish and a really bad one at 140, I'm guessing the peaks around 80-90 are going to be the true reasonance of the pipe? |
#4 |
Quarter Wavelength Loudspeaker Design
happy building. |
#5 | |
frugal-phile(tm)
dave
#6 |
I am
#7 |
The garden variety quarter wave pipe naturally reinforces some frequencies, particularly one around 4x the length of the pipe, and it nulls-out other frequencies. That is not resonance, but rather addition of the front and back waves. Stuffing is used to suppress the higher frequency comb filtering. Some designs are quite resonant however. The "mass loaded" tuned quarter wave pipe combines the effects of bass reflex (resonance) with pipe effects.
N.b. a bass reflex speaker has two resonant peaks, neither of which is the maximum of the response curve.
Davy Jones Last edited by Dave Jones; 13th June 2011 at 07:07 PM. |
#8 | |
But what I'm getting at is that the fundamental freq of the pipe can be different to that of its length, say if it is tapered or uses a coupling chamber, or to quote Augsberger, 'this is nomially a 109Hz pipe but it actually resonates at 100Hz' But I dont know why that would be, if its just due to end correction, or how you would go about finding out what its actual fundamental was And I'm well aware that MJK has tapered line tables on there but I'm experimenting with a chambered TL at the moment and I think it resonates lower than what I've designed it for but I dont know how to find out..... |
#9 | |
The peak at 140Hz could be due to floor bounce.
Davy Jones Last edited by Dave Jones; 13th June 2011 at 07:22 PM. |
#10 | |
Davy Jones |
| Need Help w/ Bass Cabinet for TAD TL-1102 & TL-1601a. Use w/ TD-4001 & Yamamoto Horn | manp111 | Multi-Way | 11 | 22nd February 2011 07:20 PM |
| TAD TL-1601a and TL-1201 Crossover Point | manp111 | Multi-Way | 2 | 27th September 2010 07:57 PM |
| Can anyone help TL or ML-TL for Alpair 10 | _henry_ | Full Range | 3 | 31st December 2008 06:31 AM |
| What's the difference between a TL, a ML-TL and a TQWT? | Bricolo | Multi-Way | 82 | 28th August 2008 02:17 PM |
| TL freq response | bigwill | Subwoofers | 6 | 13th July 2005 07:02 PM |
| Page generated in 0.11048 seconds (79.53% PHP - 20.47% MySQL) with 10 queries |
