Hello, Bought a pair of Nova-15's at a thrift shop for $10. Wanted these for my garage to be used with a T-Amp (Muse M20). They sound horrible however. Distortion is overwhelming when going past 10:00 on the volume. But cabinets and grills are great.
So, I wanna gut them and install new drivers and crossovers. I have a pair of 15-year-old Danish made Vifa D19TD I could use for the tweeters. What 8" Woofers would work well if I use the Vifa Tweeters and any crossover ideas? I'm just starting with this hobby and wouldn't mind using a prebuilt crossover. My price range is under $40 per woofer as these will be garage duty and abused volume wise. They are bass reflex but I could seal the port and go sealed if need be. |
#2 |
I had some D19TDs some time ago. If I remember correctly they are pushing it to be crossed at 3kHz. I wouldn't think they'd be a great match for an 8" woofer.
#3 |
Hmm, yeah, looking at the specs they go down to 3,500 khz and the Dayton DC200 woofer goes up to 3,000khz. Probably not a good match.
Would the PE phenolic ring tweeters work in this setup? They run 2,000-15,000. I don't mind the tweeter topping out out 15k. If this were the combo I bought would I want to crossover at 2k or 2.5k? Any thoughts? Going to start the tear-down tomorrow on the cabinets. I'll clean them out and reinforce the insides with some Durham's Water Putty Thanks! |
#4 |
That tweeter looks like it would have a slightly more narrow dispersion. Not ideal but better suited than the D19TD, and better for an 8" woofer. I'd make sure the Dayton was happy going up to 2kHz, maybe a review from someone who has heard it?
| Requesting advice on a pre-amp build. I'm working on asking realistic questions. | cbj591 | Tubes / Valves | 24 | 1st November 2010 08:14 PM |
| Help with Realistic NOVA-7B's | wksmith27 | Multi-Way | 1 | 22nd January 2010 06:48 PM |
| Budget system / Realistic Nova-10's | truz05 | Multi-Way | 14 | 16th January 2007 11:04 PM |
| Need help with Realistic Nova-7b crossover | enlightened | Multi-Way | 3 | 24th June 2006 03:48 AM |
| Gut it? | ryoshu | Everything Else | 1 | 25th May 2003 09:45 PM |
| Page generated in 0.06162 seconds (80.67% PHP - 19.33% MySQL) with 10 queries |
