Tweeter to match JX92S - Page 2 - diyAudio
Old 10th January 2013, 02:34 PM   #11
Speakerholic
Cal Weldon's Avatar
I wonder what became of this?
EDIT: I see he posted here:
Jordan jx92s GM MLTL-48 boomy bass
planet10 needs your help:
Let's help Ruth and Dave
Old 10th January 2013, 03:00 PM   #12
AntM is offline AntM  United Kingdom
Hey,
I completed the project last year - I'll post some pictures if you are interested.
I played around a bit too with "parallel" tweeter options.
My experience of using an additional tweeter rolled in above 8kHz or so is that the image focus reduces, in line with increased dispersion at HF and increased room interaction; and the listening position sweet spot widens, more or less as expected. However I've noticed that the JX92S has a pretty zingy top-end which can also be seen in the response plots. On some music material it becomes difficult to live with. Using a parallel tweeter does not improve matters and so I'm tempted to think that a full crossover may work better to reduce top end resonances.
By the way, the bass response of the design is really good - deep and dry.
Anthony
Old 10th January 2013, 03:10 PM   #13
Speakerholic
Cal Weldon's Avatar
Thanks for the update Anthony. By chance have you experimented with turning the tweeter around and firing it off the wall?
Old 10th January 2013, 03:53 PM   #14
Hi Cal,
No unfortunately not - I didn't have the foresight to include different mounting options. I've seen though that top firing tweeters and the like have become pretty popular on high-end designs these days - I think the tweeter is crossed over very high.
I think the design philosophy of a top/back firing tweeter probably fits in better with a full-range design where the dispersion is already quite wide.
Anthony
Old 19th February 2013, 08:04 AM   #15
Ant, post up some pictures!
I'd be interested in an A-B comparison of the Jordan with and without tweeter and perhaps with and without tweeter but with BSC!
I added a BSC and it was an odd sensation, though not bad just different, I think it adds something and takes something away, it's all about balancing I guess.
Old 8th April 2014, 08:24 AM   #16
portway is offline portway  United Kingdom
I am using the JX92s with some baffle step correction I have also added a pair of the JXR6 units with 0.33mf and wired out of phase. The difference using the "super tweeter" is considerable and I won't willingly return to just the JX92s
Old 8th April 2014, 03:31 PM   #17
Toaster is offline Toaster  United Kingdom
I'm not using them presently, but FWIW, Jim's design with the AC ribbon is the best sound I've had from the JX92S. No matter what the toe-in angle or use/ non-use of BSC I never could get on with them fullrange. Crossing higher could work, depending on implementation, but the blend is fine at 3kHz.
which tweeter to match with fx120 juanito Full Range 8 22nd November 2010 09:36 PM
How do I match a woofer and tweeter? chasingame Multi-Way 3 6th August 2009 07:35 PM
What tweeter to use to match the C-Quenze? trusound Multi-Way 2 23rd November 2005 01:28 PM
i need woofer to match jx92s in jakarta _henry_ Swap Meet 2 4th September 2004 04:36 PM
tweeter tweak/match paulj Multi-Way 2 21st May 2004 10:38 PM
Copyright 1999-2017 diyAudio
