Old 10th June 2011, 12:40 AM   #1
percy is offline percy  United States
Default Looking for Speaker Builder '99 article - Navigating Speaker Design
especially Part 3 where it talks about enclosure bracing. Anyone have a pdf or anything or can make a copy and mail it to me ?
Thanks.
Old 10th June 2011, 02:00 AM   #2
AllenB is offline AllenB  Australia
I have the magazine in front of me, but no scanner. If no-one else can help, ask and I could read it later tonight or tomorrow and give you the gist of it.
EDIT: I didn't read this but it looks like something by Mark Wheeler, the author of the Speaker Builder article. It is not the article but it does use the same illustration.Cabinet walls and Loudspeaker Energy Preservation - [English]
Old 10th June 2011, 02:43 AM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Thanks.
Lengthwise bracing on panels is very effective, as are plywood ribs ~3x thickness, dadoed and glued into the panels.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 10th June 2011, 02:59 AM   #4
yes, what I am looking for is the part where they conclude that vertical bracing is better than horizontal, and two part epoxy is better than wood glue.
Old 10th June 2011, 03:35 AM   #5
OK, um... tests were listening tests with a bunch of people, differences were mainly clarity and the ability to differentiate different parts of the music. Mostly the material used for the brace was more important than the design of the brace or the way it was fixed. Hardwood was best, density was important. Vertical was much better than horizontal or circumferential (shelf). Mid-panel side to side or front to back was not good enough to be noticeable. Glue was almost as important as material. Hard setting adhesives were recommended, not wood glue or hot melt.
This article seems more like a discussion rather than a proof. Not that I disbelieve it, just that there isn't much data when you dig deep.
Old 10th June 2011, 11:20 AM   #6
interesting, so there arn't any objective test and results ?
Old 10th June 2011, 11:27 AM   #7
Ron E's Avatar
I have tried vertical and horizontal, and vertical is way better. I have a friend who tried vertical ribs and that cabinet is quite stiff.
Two part epoxy - I doubt it's any better than wood glue. A good joint with wood glue is stronger than the wood. The reason they use epoxy in boat building is that it is waterproof.
Take a look at woodgears.ca - Matthias Wandel has a bunch of wood glue tests.
Ron
Old 10th June 2011, 11:37 AM   #8
No, apart from a response plot showing thicker panels forced the fundamental resonance higher, and the harmonics reduced in level. He did mention also that softwood is virtually ineffective and that he liked some powdered formaldehyde based adhesive.
Old 10th June 2011, 01:20 PM   #9
Glue - looks like its more about the stiffness/hardness rather than the strength (just like when comparing hardwood v/s softwood).
Speaker Cabinet Builder milesian Swap Meet 0 7th April 2011 10:32 PM
Help with Speaker Builder Dave Jones Software Tools 0 3rd December 2010 11:12 PM
Newb speaker builder 666ogre666 Full Range 1 6th December 2007 04:33 AM
Newbie speaker builder needs help rashnordin Full Range 1 3rd January 2006 08:34 AM
A New Speaker Builder? Smashatoms Introductions 8 23rd January 2005 01:06 AM
Page generated in 0.08726 seconds (86.94% PHP - 13.06% MySQL) with 10 queries
