kilpsch la scala
kilpsch la scala
Old 16th August 2003, 03:42 AM   #1
akersa is offline akersa  United States
Default kilpsch la scala
I was revamping the sound reinforcement in an auditorium that is on my campus, and I discovered that part of the reason that the speakers sounded so bad was due to the fact that the tweeters are both blown. The speakers are a pair of Kilpsch La Scala K447. My question is this These speakers are flown about 30 feet over head at the front of the auditorium, and they were installed in the 70's is it worth replacing or repairing the horns, or should I look at replacing them all together, I have always wondered if they were too small for the application, as it is a 400 seat auditorium. Any help with this would be greatly appreciated.
Thanks,
Adam Akers
Old 16th August 2003, 05:44 AM   #2
needtubes is online now needtubes  United States
If you head over to the Klipsch forums, there are tons of folks that can help you out. Call the Klipsch parts department... they can get you a new diaphragm or something.... shouldn't cost too much. LaScalas are about my favorite pair of Klipsch speakers... I'm dying to get some.
Old 18th August 2003, 10:51 PM   #3
cyclotronguy is offline cyclotronguy  United States
400 seats is not impossible for the La Scala's; but it is a reach. Blown tweeters is often caused by too small an amplifier, being driven into clipping.
If the end users want more volume, you might be able to limit the bandwidth seen by the La Scala's, thus giving more acoustic output where it is needed most.
While you are inside the cabinets, get rid of the feed through connections Klipsch is so fond of (machine screws with lugs on each side of the wood). These feed through connections are best replaced with continuous length of wires. The original configuration is very prone to corrosion.
You can also move taps on the autoformer to reduce the sensitivity of the tweeter by a couple of dB. In an auditorium this may help speech intelligibility and will certainly give the tweeter a bit more available headroom.
Cyclotronguy
Old 20th August 2003, 03:44 AM   #4
Dave Jones is offline Dave Jones  United States
Default Re: kilpsch la scala
Why not repair the two you've got, and add one or two more LaScalas and a suitable amp? I think you can even find plans for LaScala clones.
Davy Jones
Old 20th August 2003, 04:15 AM   #5
Brett is offline Brett
Brett's Avatar
On all the K and LS xover schems I have the tweeter isn't on the autoformer; that only affects the level of the mids. Ditto the ALK's.
Agree about the terminal connectors though.
I have a set of LS plans. IIRC they only take a sheet of 8x4 each and even I can put them together (ie quite straightforward construction)
Old 20th August 2003, 07:36 AM   #6
phase_accurate is offline phase_accurate
Why don't you tell them they were beyond repair and keep them for yourself ?
Charles
Old 20th August 2003, 05:22 PM   #7
Default squawker level
Brett,
Thanks for the correction on the tweeter.... it's been a long time since I had one of those crossovers on the bench...... obviously past my ability to remember the finer points.
Still reducing the sensitivity of the tweeter in relation to the mid (squawker) could be an advantage in a large venue with flown speakers.
I like two of the above suggestions, either add additional or tell folks in charge they can't be saved and take them home.
cyclotronguy
Old 21st August 2003, 12:28 AM   #8
zygibajt is offline zygibajt  Poland
Is it possible to buy drive units identical like the ones that sit in La Scala and make the clones?
Old 21st August 2003, 01:43 AM   #9
Brett's Avatar
Yes. Klipsch will sell all the parts as spares. There are no real substitutes to the K33 woofer and very few to the K55M mid. I'd buy all the parts, except the K400 midrange flare which is a dog. If you can get an Altec 1003/ EV SM120A that would be better, but it's a lot bigger and the Altec won't fit into the box.
The LS has an advantage over the Khorn in that you can cross it higher than 400Hz which releives some difficulty in selecting midrange drivers. For the cost though, the K55 is very good on an appropriate flare.
I also have a description of the mods to extend the bess lower by porting the cab. Easy to do if you're building from scratch.
Old 21st August 2003, 04:20 AM   #10
AR is offline AR
Default La Scala mods
Can you post a copy of your La Scala mods? TIA.
kilpsch la scalaHide this!Advertise here!
Klipsch La Scala Help t-head Multi-Way 6 2nd April 2008 07:07 AM
bass section horn klipsh la scala jbsteeple Multi-Way 2 31st July 2006 06:28 PM
Klipsch La Scala Duck-Twacy Pass Labs 17 14th August 2005 10:15 PM
Copyright ©1999-2017 diyAudio
