Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Multi-Way Conventional loudspeakers with crossovers |
#11 |
Do You have any idea what would be the cost of drivers (I suppose 6 of them)?
I was thinking about building something like this.I also thought about a clone of Altec Model 19.There are plans for the enclosure and drivers are easy buyable on Ebay.I also found schem. for ALK crossover as an up-grade of La - Scala.Can you recommend enything? I want high sensitivity ,huge dynamics,extremely fast,life like sound. Bartek |
#12 | |
![]() Quote:
You can read more here LaScala mod . This mod works best with other drivers than the K-33E. I've used the JBL 2226H. The backchamber is enlarged to 4.8 cu.ft and tuned to 30Hz. Frode |
#13 |
Reviving an ancient thread for a relevant question
![]() I've built a lascala bass bin with the djk mod integrated (thanks djk, it works nicely). I've been using a dcx2496 so any of the 'shaping' necessary to the bass is easy. I want to get the dcx out and I am wondering if anyone knows the details of what djk has in mind for the passive circuit. I've searched like crazy and I guess I'm hoping djk is tuning in ![]() Thanks
Crazy Yankee. |
#14 |
Hi guys,
What is the frequency range of the bass & will it go up to 500hz? I want to put a round 50cm midhorn on top of one of these. |
Thread | Thread Starter | Forum | Replies | Last Post |
Klipsch La Scala Help | t-head | Multi-Way | 6 | 2nd April 2008 06:07 AM |
bass section horn klipsh la scala | jbsteeple | Multi-Way | 2 | 31st July 2006 05:28 PM |
Klipsch La Scala | Duck-Twacy | Pass Labs | 17 | 14th August 2005 09:15 PM |
New To Site? | Need Help? |
