I've got a pair of DENON SC-C3 from my uncle. It is two ways speaker use 1 woofer and 1 tweeter per cabinet.
I've dismantled the parts to see inside and founded that the tweeters was wired in phase on one and the other was out of phase from the factory.They use 2nd order passive crossover network. So now I can't remember the left or the right tweeter was wired out of phase or mayby I could be mistaken that actually both of Left and right was wired out of phase from the factory . I was very confused I need some help. Please give me suggestions about the wiring of tweeters what should I connect them ? Should I wiring them both out of phase ? or only one cabinet out of phase and if wiring only side It should be Left or Right side. Thank you. |
#2 |
No, both speakers should be (from my point of view) the same, unless they were not symmetrical (exception).
Phase then (or not), it's the final adjustment in relation of the speakers (drivers) and xover (xover/order) and xover frequency. (You can test both). Describe or post a picture of xover. Last edited by Inductor; 8th June 2011 at 12:17 PM. |
#3 |
Here are some pictures of xover. It's uncomplicated design using C 3.3uF in series with and 0.47mH Inductor parallel with the tweeter.
#4 |
red ==> + woofer
black ==> - woofer orange ==> ? tweeter white ==> ? tweeter |
#5 |
the wiring diagram which I knew.
red ==> + woofer black ==> - woofer orange ==> ? tweeter white ==> ? tweeter |
#6 |
If the photos you show are the entire crossover, than unless there are some components hidden from view, that is a first order 6dB crossover. One inductor for the woofer and one capacitor fro the tweeter. The woofer and the tweeter should be wired in-phase for both speaker cabinets.
A 2-way speaker using a 2nd order 12dB crossover has the tweeter wired out-of-phase. Edit: It is difficult to tell from the photos, are those components indeed only connected to the tweeter? Are you sure the inductor is not in series with the woofer and the cap in series with the tweeter?
Single-Ended Tube Amp Kit Last edited by scott17; 8th June 2011 at 02:28 PM. |
#7 |
probably best with reversed phase on tweeter
but depends if your xo is made to work without reversed phase, things might get more complicated note that the reversed connection can be done either at xo, or at tweeter I'm sure you must be missing some attenuation on tweeter |
#8 | |
#9 |
It's 4kHz crossover with 6 ohms tweeter.
#10 |
In that case I would wire woofer and the tweeter in-phase. Since there is no crossover on the woofer, there is no phase shift. The tweeter crossover does cause phase shift but the woofer and tweeter will not be 180 degrees out of phase. I built a set of 2-way, 1st order on the woofer, 2nd order on the tweeter, and wired them in-phase.
Single-Ended Tube Amp Kit |
| Wiring from xover to tweeter | cpu8088 | Multi-Way | 1 | 11th January 2007 10:10 AM |
| Why this tweeter phase not inverted? | andy2 | Multi-Way | 5 | 14th March 2006 12:12 AM |
| Checking tweeter phase | eRiCdWoNg | Multi-Way | 3 | 1st October 2005 11:11 PM |
| NSB wiring and phase plugs... | nerd of nerds | Multi-Way | 14 | 6th January 2005 10:25 PM |
| +/-/+ Phase Wiring Question | Maelfactor | Multi-Way | 12 | 29th May 2004 06:04 PM |
| Page generated in 0.11567 seconds (82.58% PHP - 17.42% MySQL) with 11 queries |
