Old 6th June 2011, 10:18 PM   #1
Default Kid friendly project
I have a pair of 2" drivers and a pair of planar (?) tweeters from a set of Monsoon computer speakers. I'd like to build a speaker with my daughter, for my daughter. I'll run a TA2020 chip amp to them.....she can hook up her ipod or cd player for a source.
There are no markings on the drivers or tweeters. What I'm planning is a little box for the 2" speaker with the planar mounted on top. I can't imagine as the box size for a 2" speaker is that important?
Keeping in mind she is 8 and I want it to be mostly hands on for her......how would you run these? Can it be as simple as a single resistor in line with each speaker? We're not shooting for audiophile sound here. I want very simple and something we can run to Ratshack and get.
Thanks in advance for the ideas!
Old 6th June 2011, 10:29 PM   #2
kevinkr's Avatar
At the minimum a capacitor in series with the planar tweeter, and honestly probably a small inductor in series with that 2" woofer. Ratshack doesn't exactly offer a lot of parts, good or otherwise for making speaker X-O these days. I would expect the results not to be very good with this seat of the pants approach..
Why not take a look at some of the inexpensive Tangband full range drivers at Madisound and elsewhere - given the extreme simplicity you seek this would probably yield much better results. Who knows you might make an audiophile of her..
www.kta-hifi.net
Old 6th June 2011, 10:41 PM   #3
sofaspud's Avatar
I think I'd look for something like a pair of wooden cigar boxes, Hello Kitty pencil boxes, etc. Simplest xover is just a capacitor on the tweeter. Then you and she can focus on the three b's - baffle, bracing, and binding posts.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 6th June 2011, 10:53 PM   #4
Thanks sofa.......any idea what size cap for the tweeter? I think I have the perfect thing for boxes
Old 6th June 2011, 10:59 PM   #5
nigelwright7557's Avatar
Originally Posted by 503Timber View Post
I'd like to build a speaker with my daughter, for my daughter. !
Safety first, warn her about electronics and electrics that bite !
When I was 10 I had a go at fixing our black and white TV.
I swapped out valves until it started working again.
I dread to think what would have happened if I touched the tube !
My brother at 6 wired up a plug with a wire from live to neutral then plugged it in, he was very white faced at the bang !
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 6th June 2011, 11:08 PM   #6
godfrey is offline godfrey  South Africa
Weren't there caps in the computer speakers you swiped the drivers from? Otherwise I'd take a wild guess and say 4.7uF
Old 6th June 2011, 11:10 PM   #7
RIP
pedroskova's Avatar
The monsoon drivers, by reputation, are quite good and were designed to go quite low. One possibility would be to wind your own inductor using RS magnet wire for a calculated 1kHz xover. Or, like sofaspud mentioned, you could take advantage of the 2" 's bandwidth and just use a cap on the tweeter to blend. I think the first might sound better (or not) if you do have actual monsoon drivers ... and it would only cost ~ 3 bucks in magnet wire. I've actually done this for 4kHz lash ups in a pinch, and it worked fine.
Old 6th June 2011, 11:16 PM   #8
scott17 is offline scott17  United States
scott17's Avatar
Not shooting for audiophile sound?
OK, she's 8, why would you want to ruin her concept of good sound by building a crappy set of speakers? Just my opinion.
There are plenty of designs for a small set of speakers that are NOT crappy.
No intent on disrespect whatsoever, just build a great set of speakers. No reason not to.
Single-Ended Tube Amp Kit
Old 6th June 2011, 11:45 PM   #9
Well she is 8.....and so are her little snot nosed friends. Last thing I want is a finger in a pair of Fostex. .........and I have the parts.
Old 7th June 2011, 12:22 AM   #10
tinitus is offline tinitus  Europe
your planar tweeters will be much louder than a 2"
Hi from a new Kid on the Block. Valvepower Introductions 1 26th January 2009 05:00 PM
New kid in town... BlueRob Introductions 4 7th December 2008 12:52 AM
New Kid In Town cujo75 Introductions 3 27th October 2006 07:17 AM
Hi, I am new kid in DIY!. boxedin Introductions 3 23rd December 2005 04:14 PM
New kid, and some questions! xstephanx Introductions 1 30th October 2004 07:49 AM
Page generated in 0.09673 seconds (87.10% PHP - 12.90% MySQL) with 11 queries
