4 ohm drivers in series w/ crossover
Old 4th June 2011, 02:40 PM   #1
Einric is offline Einric  United States
Einric's Avatar
Default 4 ohm drivers in series w/ crossover
So, thanks in advance.
I'm wanting to place a 4 ohm tweeter in series with a 4 ohm woofer. I am wondering if I can still place the crossover components in with their respective drivers.
I'm thinking no since the high pass crossover pieces in the chain for the tweeter would block the low pass before it reached the woofer.
Any Help Is Great.
Old 4th June 2011, 04:40 PM   #2
Arty is offline Arty
Series vs. Parallel Crossover Networks
this will probably help you out.
just take he time to read it from the start to the end.
Old 4th June 2011, 05:42 PM   #3
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
If you have a 4-ohm woofer and a 4-ohm tweeter and make a two-way system with them, even with a series crossover the system nominal impedance will still be four ohms.
Old 4th June 2011, 07:31 PM   #4
Einric's Avatar
That makes perfect sense.
Thank You Both
4 ohm drivers in series w/ crossoverHide this!Advertise here!
8 ohm Crossover with 4 ohm Speakers nkx1 Parts 2 24th February 2010 11:04 PM
Can you use a 8 ohm crossover with 4 ohm speaker? Bull Subwoofers 1 19th May 2005 08:37 PM
Dipole - 4 ohm in series or 8 ohm in parallel? cheesehead Subwoofers 1 1st December 2004 07:53 PM
What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? The Paulinator Multi-Way 9 11th May 2004 07:04 PM
Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better? Cal Weldon Multi-Way 16 21st February 2004 12:31 AM
