what effect does a 4 driver have on an 8 ohm crossover? - Page 3 - diyAudio
Old 5th June 2011, 03:48 AM   #21
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by AllenB View Post
......and text book component values as I would expect in this unit.
well, we assume a 150hz xo point, because it says so
its obviously a calculated xo
and we know for a fact that it would have delayed function in real life
low crossing inductors always needs to be bigger than calculated
sometimes quite a lot
and with such low xo point, even more
as said earlier, the 150hz xo point would be more likely to happen now, with 4ohm instead 8ohm
I would be very surpriced if it would be much lower than that
Allen, the very low xo point you show in the third graph is unlikely to be that low with such small inductors
thats why I question it
Old 5th June 2011, 04:24 AM   #22
AllenB is offline AllenB  Australia
There is something in what you are saying. I decided that I didn't feel the impedance I used for the sub was a good example so I changed to another woofer and this time I have displayed the impedance.
Originally Posted by tinitus View Post
needs to be bigger than calculated sometimes
This being one of those sometimes cases as the impedance is falling at these low frequencies, not rising as it usually does near a crossover point.
The ideal plot is in green. 8 ohm is orange, 4 ohm is blue (same impedance plot used but filter Q halved), and the impedance is in grey.
Old 5th June 2011, 05:12 AM   #23
ouch, a 100hz 'peak woofer', that would not be very nice
Old 5th June 2011, 05:58 AM   #24
I agree. I found what looks like a 4 ohm driver with a lower resonance hoping this will be more helpful. I managed the second plot by more than halving the inductance and tripling the capacitance. The third has an inductor 2.6 times smaller and capacitance quadruple the original, as well as a resonance peak filter.
Old 5th June 2011, 01:34 PM   #25
60ndown is offline 60ndown  United States
sure wish i knew what parts to solder (and where to solder them) into my cheapo x over to make it perform like graph 3
currently it sounds pretty good, if there is a big peak at 100hz im not hearing it, i can hear some mids coming from the sub when i get close to it, from more then 6 feet away it sounds reasonably good,
but i wasn't expecting too much for my $8.
typically im a fan of a sub that plays nothing above 60 hz
Old 5th June 2011, 01:56 PM   #26
Room modes are playing a big part at these frequencies and peaks like that may or may not turn out to be significant on their own by comparison. Room placement makes changes easily this big. Have you ventured into the world of multiple sub placements to balance the bass?
Old 5th June 2011, 02:12 PM   #27
interesting,
no 'multiple sub' arrangements for me yet........
Old 5th June 2011, 02:36 PM   #28
If you happen to have two for stereo anyway, try putting one in a corner and one halfway along one of the walls, then try swapping + and - for each of the subs one at a time.
Since you asked...but these values may not quite work for your woofer.
Old 5th June 2011, 02:57 PM   #29
definately yes
you may have severe 'suckout' at very narrow frequency
or even excessive room gain right next beside it
take everything with 'some' precaution
whether its something being said, claimed, or simulated
or even real time measurements showing perfection may not sound like that at all to your ears, or in your room
sound is tricky, music even more
that said, no one wouldn't normally try to do a passively crossed sub
at least not anyone around here
but if so, a bandpass design ought to have better chances
Old 5th June 2011, 03:51 PM   #30
il be posting pictures soon
Effect of driver resonance on crossover Alex M Multi-Way 17 5th December 2010 05:33 AM
Effect of adding 4 ohm resistor to tweeter uzernaam Planars & Exotics 19 6th November 2010 01:08 AM
Effect of tweeters on ohm impedance? Flyin11 Car Audio 3 28th February 2008 05:46 AM
Putting an 8 ohm L-Pad for 6-ohm driver? nobb Parts 0 3rd June 2007 07:20 PM
Can you use a 8 ohm crossover with 4 ohm speaker? Bull Subwoofers 1 19th May 2005 08:37 PM
Copyright 1999-2017 diyAudio
