Why are OMNI speakers not more popular? - Page 89 - diyAudio
Old 12th December 2016, 10:22 PM   #881
graaf is offline graaf  Poland
graaf's Avatar
Directivity
"high phooey and hystereo" - Yascha Heifetz
Old 14th December 2016, 05:42 AM   #882
jerryrigged's Avatar
Thank you, graaf. I'll give that a listen...catch up on current thinking by some of the better minds regarding the subject.
I've always kept in mind Linkwitz' comment 'ignore the room'. I've had to do just that nearly everywhere I've lived with whatever speakers that happened to be along for that part of the ride. Decent omnis IMHO at least make the approach properly, recreating the space as opposed to hosing one down with directed sound.
I still have my atypical 'typical' speakers, but I use them more as a reference point than as 'daily drivers', to steal a phrase...although any speaker has it's own 'voice', much like us. I've noticed that with my objects; although they're of different physical size, there's a commonality as to How they sound, what their 'voice' is like given the same input. You can definitely tell they're cousins. *G*
"Do what you can't." Exactly; my rational...
Old 20th March 2017, 02:01 PM   #883
This was a very interesting read. I'm considering to either build some omnis myself, or to buy one of the commercial offerings. My experience is that omnis can sound more natural than frontfiring speakers.
Just a related question to the omni owners out there: Do you have any thoughts/experience on proper acoustic room treatment for omnis? Most of the existing advise for room acoustics are geared towards conventional forward-firing speakers, so I don't know if it's applicable for omnis. Concerning the back wall behind the listener for example: Would it be a good idea to leave this relatively untreated, or add some cheap absorbtion, or diffusers? As I understand it, the ideal thing for omnis would be for the reflections to come back as "pure" as possible. If it's an absorber that only takes up parts of the frequency range, that could be a problem for example, so a diffusor could work better.
(if it's ok that I'm asking about it in this thread)
Old 20th March 2017, 02:19 PM   #884
DonVK is offline DonVK  Canada
DonVK's Avatar
I think there are 2 schools of thought on this. One view is directivity, min reflections and localization is primarily important for a technical listener. The other view is that spaciousness and reflections are key to pleasing sound even if it sacrifices some localization detail. I'm in the latter camp. Some reflections are needed, otherwise you'd use an anechoic chamber or an open field as a listening room (neither is pleasing). The debate is in the degree and hence your preference, and hence never solved :-)
Authors like Floyd Toole have studied this extensively and its the theme of his book. A true Omni has the exact same response 360deg around and by definition has constant directivity. They spray the room and provide excellent lateral reflections from the walls, and they sound very natural and spacious (to me anyways). I don't treat the room, but I place the speaker >1m from any wall, furniture and carpet is enough damping, and don't sit against a wall. Still working on mine.
OmniDirectional - work in progress
Old 20th March 2017, 03:22 PM   #885
Thanks, DonVK! Interesting to read about your experiences. I'm to a certain extent in both "camps": I like very detailed pinpoint imaging, but also like very much to have a airy and spatial sound. The question is whether one can have both...
Interesting that you don't treat walls at all. I currently have absorbers on the back wall, but maybe that won't be needed with omnis.
Old 20th March 2017, 03:33 PM   #886
DonVK's Avatar
According to Toole, reflections from behind are not helpful. Your back wall treatment is probably better. I have large windows on 3 sides so absorbers are not really an option for me, and I don't seem to be bothered by back wall (window) reflections.
Old 23rd May 2017, 05:21 AM   #887
BTW....I'm back. *S* Hi, y'all. *S*
After 7 wks. in FL & 2 wks. of recoup', restoration, and relative 'nice, normal chaos' it's nice to be able to take a moment and see if anyone's still 'listening'.
Anyhow...have picked up the parts and started doing some assembly on the V.4's. The CNC'd bases have been laid out and drilled, the tweets have been installed into theirs, and patterns are about to be created for the surrounds and assembly routines on the main cones. Tubing and hardware will begin to be cut after some 'fine tuning' of lengths...just to be sure, as 'stretchers' for that sort of thing are in short supply...
Have had 9 wks. to consider cone fabrication, still a major routine to get into. Rolling them is still a hands-on activity that demands time, patience, and a high degree of attention and care. I'm planning on doing a 'test crash dummy' or three to ensure I can create 4 final ones that exhibit a high degree of duplication and quality control.
Getting my head back into the quest has taken some 'goofing around' with side projects, just to 'warm up' the hands that will do the deed...
...and I'm just about There. *G*
DIY Omni Directional Speakers Magnetar Multi-Way 69 27th October 2016 03:38 AM
Why aren't coaxial speakers more popular? Tyson Multi-Way 237 9th February 2016 04:33 PM
omni directional speakers dvsound Introductions 4 25th November 2007 03:21 PM
Any ideas for el-cheapo omni speakers? Spasticteapot Multi-Way 4 8th November 2006 01:14 PM
Copyright 1999-2017 diyAudio
