Ohm Walsh drive is somthing special...
But do we have modern directivity measurements of it?
More omnis Omnidirectional speakers
I have a pair of OA-15
Hi, 'hazi....Y'know, I've not run into any and would appreciate, nay, fall over to see any. They're known to be difficult at best to 'read' because the radiation pattern 'shades' any direct measurements.
I'm inclined to think the only way to get something serious would be in an anechoic chamber, surround it with 4 closely matched calibrated mics, run Those through an 'averaging' routine, and see what comes out...
Somewhat beyond most typical testing, and certainly beyond the DIYer unless one has more $ and spare time than 99.99% of us as a whole.
I have noticed...and IMHO, obviously....that when you have 4 of them in a surround array in a larger space that the reflected sound 'seems' to begin to be 'overridden' by the 'direct' sound....
Observations:
1-db & low fq response 'rises', even for the smaller cone sizes I'm deploying.
2-clarity improves on the hf
I'm frankly not totally surprised by the above; any surround system will yield such. What is interesting is movement within the sound field away from the dead center 'sweet spot' (Yes, it's there) brings into play direct/radiation effects without use of any delay on the 'rear' (subjective; it's a 2 chan. input/output, no use of eq. F or R individually)....
Instruments & vocals begin to move about. Now...this may be an effect induced by the modern mixing tech and techniques that are employed. Some selections just 'play flat', almost 'mono' in their perceived 'sound field'.
But some of the more current music, esp. the ones that are 'noticeably cleaner' response....
It get erie...but delightful to experience.
If you can try this routine, let me know what you hear....or think you're hearing. I'd like some feedback on this....
Either that...or I'm simply going more 'bonkers' than y'all think I am already.*L*
...but, Hey. I'm good with either. *LOL* 😉
Observations:
(I'm not claiming that Walsh or omni measurements don't exist. Quite the contrary.
But...
I already 'have a life' which precludes 24/7/365.25 searching @ this keyboard, geeking out like a MUD gamer....
I've run into 'them' before. Not my lifestyle, nooo. *L*)
But...
(...and NO....I'm not into 'meth'. I've seen 1st hand what that does to one. It's the name of the artist(s). I just like EDM. It's great stuff to run the daylights out of speakers, an audio obstacle course that'll stress-test any material adhesive I can get my mitts on.)
Happy New Decade...
Anyway...have finally gotten about to adding hf drivers to 3 of the 4 pairs of Walsh 'full range' drivers that have survived my use 'n abuse....
Now starts the 'taming of the new beasts', since they're already exhibiting 'cone honk'.
Simplest way of describing that characteristic is the way one sounds when using a megaphone....that 'honky' sound is gives one's voice (or anything else, for that matter)... Think Rudy Vallee's vocals of days' past.....
Yes, that does indicate how old I might be....*L*
It also should show t' go ya Why I can claim "Yes, I know what tubes sound like...Yes, they've improved....Yes, I'm 'solid state', and think class D isn't sent from Hades to mess with us...." 😉
'Cone honk' I can cure ....rather easily, actually...*S*
It's the newer demons that will need to be quelled...
The quest continues....
Nothing new but omnis are getting more popular as non-hifi home distributed sond systes, like Sonos.
Here Klippel NFS measurements of an exceptionally well executed B&O Beosound Balance speaker, 3000€/piece. Long tradition...
https://www.audiosciencereview.com/...s/bang-olufsen-beosound-balance-review.56971/
I haven't heard these, but I have a pair of old Sonabs from 1980's. Stereo imaging is so-so, best use scenario is as mono ambience background, IMO.
Omni have been flooding the home market since the mono HomePod and short-lived stereo upgrade. Even variations of LX etc. show up mass-market, from time to time.Nothing new but omnis are getting more popular as non-hifi home distributed sond systes, like Sonos.
For "hi-fi" I'd call the newly released Mark Audio MA200 (I got the first pair sold in China on Nov 1 Single's Day), used low-omni straight-through in tapered TL, as "good stereo", soundstage floating mid-air beyond front wall. At 24hr run-in, by-ear and umik1 flat response to at least 15khz when used 45-75° off-axis like this. Bass extension was not tested due to driver not fully (100hr) run-in, but 8" AlMg cone ought to be decent in the right cab.
I stopped working on the MA200 when I heard the long-out-of-stock legendary MAOP10.2 and made a snow-cone omni.
I kept losing ping-pong balls (probably too small but see below) and didn't want to use my souvenir baseball.... Just tried again larger round shapes but most very-HF, produced near the dustcap, bounced down instead of out. Before the dangerously-close big pointy snow-cones I had tried smaller cones cut from paper cups, then cooked salted goose eggs, then added "piece-of-tape" pointy goaties (to excellent effect). Still room for improvement above 10khz, but (listened...A sphere might work quite well as a reflector. Safer and easier to find - maybe a large plastic Xmas tree ornament?
And this Scorpion "stealth bomber" isobaric.Not better directivity because the motor blocks high frequencies and makes huge diffractions. But perhaps that might be beneficial considering using it as omni...
About two months ago during a survey of some old 15" drivers for my reflector-point-source experiment (see Fullrange Photo Gallery), I was surprised to hear what @dcgold @CharlieLaub charts showed, for the Peavey Scorpion! Whereas the front dustcap attenuated HF above ~4khz, the curvilinear cone (see picture) actually radiated to the rear sides at least to ~9khz. I had a pair of them isobaric face-to-face over stacked cubes -- the bass was good, and so was the treble after topping with a wash-basin/bowl 360° "horn" (to be improved; a bit of "treatment" to the basket is also...
Speaking of omni horn loudspeakers, the commercial firm Duevel has some nice examples.
- Why are OMNI speakers not more popular?
