diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   TS parameters and added series coil (http://www.diyaudio.com/forums/multi-way/190092-ts-parameters-added-series-coil.html)
jamikl 2nd June 2011 07:18 AM
I have asked this on another thread but no response. Panomaniac and a few others have suggested that sometimes a series coil should be added to the woofers on an open baffle, presumably to cut the high end a bit. Does doing this alter the TS parameters in anyway or is it only the resistance of the coil which makes a slight difference to Qes?
jamikl
AllenB 2nd June 2011 10:07 AM
They both have an effect but the resistance is normally the only one worth worrying about, and you may even be able to ignore that.
flg 2nd June 2011 11:11 AM
Of coarse you are refering to Inductive Reactance? But, there is also resistance(DCR). And they both play a role in the voltage/frequency across the driver. :D
speaker dave 2nd June 2011 11:36 AM
Originally Posted by jamikl (http://www.diyaudio.com/forums/multi-way/190092-ts-parameters-added-series-coil.html#post2592086)
jamikl
Thiele Small parameters are an idealized look at the woofer bottom corner response and as such don't capture the effect of woofer impedance beyond DCR. (As you say, impacting Qes) External crossover components should be considered as a secondary response shaping block preceeding the T/S defined woofer/cabinet response system. It is complex in the end, because high inductance can shift electrical resonance somewhat.
T/S predictions really work best for systems in 2 pi (half space) with minimal network or inductance.
David S.
jamikl 2nd June 2011 11:57 AM
Thanks to AllenB, flg and speaker dave.
jamikl
woody 2nd June 2011 01:27 PM
Here is a calculator to find the effect on qts with an added resistance.
http://www.mh-audio.nl/newqts.asp
rabbitz 3rd June 2011 05:42 AM
Generally keep the DCR of the inductor to < 10% of the driver's Re for a small as possible change in driver Q (Theile JAES 1976).
There is another figure of < 5% of the driver load impedance (incl impedance comp circuit) at the xo frequency.
Copyright 1999-2017 diyAudio
