Side firing port for bass-reflex
Old 1st June 2011, 11:16 PM   #1
scott17 is offline scott17
Default Side firing port for bass-reflex
I am working on a 2-way bass-reflex/horn tower configuration speaker design. The cabinet is 48" tall with the woofer and horn located at the top front of the speaker box. I have researched this quite a bit and I see no reason that the port cannot be located on the side of the cabinet at the bottom since the quarter wave of the tuning frequency is well within tolerance. I have seen ports located on the back of the cabinet, however I believe if placed close to a rear wall there may be some detrimental effects. With the port on the side, it would afford placement with the port firing in towards the center if the speaker is to be placed close to an outer wall.
Does anyone here have any comments or experience regarding port placement in this configuration?
Old 1st June 2011, 11:26 PM   #2
I should clarify the reasons for wanting to place the port on the side.
Due to the construction methods, I have calculated that the depth of the side bracing can be used very easily to construct the port. The distance from the outer panel, through the bracing, with the addition of a couple of other cross braces will match the tuning frequency of the cabinet design.
Thanks.
Old 1st June 2011, 11:31 PM   #3
AllenB is offline AllenB  Australia
A port needs to be fairly close to a wall to make a significant difference. If you plan on tuning the port lengths with the speakers in their position in your room, then there shouldn't be a problem either way.
Side firing port for bass-reflexHide this!Advertise here!
Bass reflex port question Javachip Multi-Way 12 11th April 2006 12:11 PM
Tuning bass reflex port beamnet Multi-Way 0 28th September 2005 01:03 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Q-factor of bass reflex port SSassen Multi-Way 6 26th March 2005 08:26 PM
Copyright ©1999-2017 diyAudio
