#71 |
Hi Vikash.
I have a pair of RTL2's which Ive modded so I thought you might like to see what I've done to them. Maybe you have some tips for me also? Thanks, Mike. RTL2 Modding
www.drugfreeworld.org |
#72 |
Hi All
I am new here and was drawn to the forum when i was searching for mods for the RTL3. Yes bass is great from this budget speaker, but the highs could be tamed. Mine are 17 yrs old. Vikash what tweeter did u settle on. Vifa? And yr X over mods entailed better components and just the L pad pots? Thanks Shahrin |
#73 |
Dilletante, tinkerer and beggathoner supreme
Vikash ? Which TDL model??
I know that in some with dual woofers they used woofers with different impedances to even out the load on the amplifier, so having a driver with 16 Ohms sounds about right, the other in the box should be 8 Ohms (Nominal)
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#74 |
Greetings all
For anyone who is interested due to a failed bass driver i reworked the speakers completely and this thread was one of the references used so only right and just i post my results back .Orignal mid/bass units were apparently based on SPH 175's with some changes requested by TDL. As i wanted to "upgrade" i built a config around the SPH176, similar but more powerful unit it received good reviews from a german reference and was used in a setup herre which helped point me in the right direction: http://www.humblehomemadehifi.com/download/Humble%20Homemade%20Hifi_LBS_copy.pdf The tweeter was replaced with Morel Cat378, mainly because its the same size, is reasonable priced and its sensitivity matched the twin 176's so the crossover was easier. The original crossover components were all v cheap and having replaced a burnt crossover not long after purchase i noticed when refurbing that despite being an RTL3 part the cossovers weren't identical! I could only win from there... I plotted FR and impendance curves from the drivers and used the Bagby spreadsheet to get an understanding of what results different component values gave. After some listening and tweaking I ultimately built a first order crossover using poly caps and air inductors with zobel for the woofers. Its fair to say the speakers are far from what they were - very enjoybale, shame i would need to buy a stadium to let them really sing . This was some time ago now but happy to dig out the specifics and photos if anyone's interested.
| TDL RTL3's -Advice needed! | bertieduff | Multi-Way | 17 | 14th September 2010 04:14 PM |
| TDL RTL3 Blown Mid Bass unit | Fanuc | Multi-Way | 11 | 8th April 2009 03:25 PM |
| dimentions of speaker box in speaker spec sheet? | Dan2 | Car Audio | 2 | 6th February 2009 05:34 AM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
