Rehousing speaker - TDL RTL3 - Page 6 - diyAudio
Old 21st November 2006, 08:10 AM   #51
pinkmouse's Avatar
Hi Vikash
Sorry I wasn't around much this weekend, real life got in the way a bit. The first thing I see is those lumps on the FR chart. They look too regular to be from the driver, is it possible you have some room effects creeping in? Are they nearfield or at 1m? Could even be beaming...
As for the crossover, it looks pretty good, though you might have fun making up some of those cap values. What did the existing TDL3 cross over at? I can't recall.
Haven't done much with the PC for the last week or so, I need to get it all up and running again. Briccolo suggested using the KX drivers for my Audigy SC, as I was having issues with the Creative drivers after a nasty PC crash, so I should, (hopefully), get on that this week.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 21st November 2006, 12:37 PM   #52
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
I think that's the comb filtering effect of the MTM. The measurements were taken at 1m. At 0.5m and 2m the same ripples are present.
I measured and modelled the original xover and guess what!? It's uses half the parts and models better! Nothing to do here.
The grey line is my crossover. The black line is the original crossover. They know a simpler/better way to get round the L-Pad and notch filter that I couldn't do without. I obviously have a lot to learn yet!
V
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 1st December 2006, 09:46 PM   #53
Vikash's Avatar
Default Light at the end of the tunnel...
I did some more measurements today with the new crossover parts in place. It's the same xover design as the original (as per my previous post) just changed all the parts for half decent ones from Madisound.
My main concern with the measurements is the small null at 2.5k. All drivers measure ok when measured individually as can been seen, but when measured as a whole there seems to be an issue. I've pulled my hair out with this but I'm sure there's a simple explanation for it...
I'm going to pad the tweeter down a bit which may or may not take care of the not-so-nice top end of the original TDL's.
Old 1st December 2006, 10:38 PM   #54
pinkmouse's Avatar
Default Re: Light at the end of the tunnel...
Originally posted by Vikash
IMy main concern with the measurements is the small null at 2.5k.
Hmm. I never measured mine, but now you mention it, it wouldn't suprise me if it was there all along.
Old 2nd December 2006, 09:47 AM   #55
Vikash's Avatar
What wattage resistors are needed for the L-pad?
Old 2nd December 2006, 03:30 PM   #56
pinkmouse's Avatar
5w should be fine, (a guestimate without doing the maths), as the tweeter doesn't see a lot of power.
Old 2nd December 2006, 04:06 PM   #57
Vikash's Avatar
Grrr that means ordering more parts. I was hoping the 2watters I have lying around might suffice.
Old 2nd December 2006, 04:10 PM   #58
pinkmouse's Avatar
Try 'em. Run some music at decent levels through the system for five minutes or so and see if they get hot. Or if you have lots, series/parallel them up, then they'll all share the dissipation.
Old 2nd December 2006, 08:33 PM   #59
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Must be your -z and -Y +Y acoustic centres data. Plus that last octave rise looks suspicious. Maybe its your mic climbing due to edge diffraction in that 6mm brass tube. Is it checked against some other mic?
Old 4th December 2006, 07:13 PM   #60
Vikash's Avatar
Hi Salas, I thought maybe I had made a mistake somewhere with the wiring but since that null measures the same even with the original crossover I don't see anything I can do about it.
I haven't 'checked' the mic against another. However my measured response follows the tweeter datasheet so there's no concern for me there.
One things I'm learning is that the MTM topology stinks.
TDL RTL3 Blown Mid Bass unit Fanuc Multi-Way 12 9th February 2016 06:06 PM
TDL RTL3's -Advice needed! bertieduff Multi-Way 17 14th September 2010 04:14 PM
dimentions of speaker box in speaker spec sheet? Dan2 Car Audio 2 6th February 2009 05:34 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 10:12 PM
Copyright 1999-2017 diyAudio
