My Pyramid speakers are gone and it is time for a new project.
The goal is to try to reduce the footprint from the original speakers which had a 24" by 24" footprint. I want to reuse the Acoustic Elegance TD15H drivers, but wanted the simplicity of a 2-way. A horn is one way, but I have become interested in the Beyma TPL150 AES driver. I want high SPL because the amp is a tube amp that drives it. According to John (from AE) a good place to start the crossover is about 1.2kHz and the Beyma should just do that. This is the basic concept (see renderings). The top is angled back 8° to point the Beyma at the listening position. Other than that, I have made the cabinet as narrow as I can so that I get about 5 cubic feet internal volume after the ports, speakers, and internal braces are subtracted. The cabinet is two layers of 3/4" baltic birch with Green Glue between the layers to make constrained layer panels. The 17" wide face yields a 238 Hz baffle step that needs to be accounted for. I would be interested in your thoughts on the idea before I get too far with the detailed design stage. Thanks in advance. ![]()
| Help needed ! Inter M R300 schematics needed ! | alexclaire | Solid State | 30 | 9th September 2009 06:14 AM |
| LT1964-adj Help Needed or Part Needed | lgreen | Parts | 2 | 29th June 2007 02:50 PM |
| Sub Help Needed | Audio_N00b_xB | Subwoofers | 9 | 26th September 2005 04:03 PM |
| HELP needed | uli | Multi-Way | 3 | 10th July 2003 06:53 AM |
| Page generated in 0.06052 seconds (66.75% PHP - 33.25% MySQL) with 10 queries |
