Old 31st May 2011, 12:42 PM   #1
Default Tannoy dc3000 capacitors help
Hi all can any one help i have changed the standard caps for some monacor plasic foil caps. Thay have been in the speakers for 2 months now but sound very bright and agresive as any one used these caps any help would be great
Old 31st May 2011, 01:08 PM   #2
AllenB is offline AllenB  Australia
Just a thought, have you played with padding the tweeters down a little?
Old 31st May 2011, 02:23 PM   #3
Hi allen thanks for reply yes i have been messing with different amounts of wading but thay bstill sound really shrill at the top end. Im not sure what type the caps were that i took out but thay look like electrytic caps the ones i have have put in were monacore plasic foil thay are more detailed but i cant stand the shrillness
Old 31st May 2011, 02:39 PM   #4
Hi bull, no I meant increasing the tweeter resistors.
Old 31st May 2011, 04:10 PM   #5
Sorry i thought you meant the damping. No i have not touched the resistors as these are the first speakers i have built. I have copied the oroganal dc 3000 plans apart from the port should be slotted and i have put a round port in the back
Old 31st May 2011, 09:51 PM   #6
Some capacitors have a built in resistance. I won't presume to guess how much in your case, but you aren't the first to have this issue. I'd try this all the same (maybe one or two ohms leading to the tweeter crossover to begin with)
Old 31st May 2011, 11:00 PM   #7
Hi allen thanks for help i will try a 2ohm resister then unless i try different caps are plasic foil caps the best or shold i try some electrlic caps or may be different type what do you think the best option
Old 1st June 2011, 09:42 AM   #8
Polypropylene foil are thought to be the best. Electrolytic can sound very good if you get a good one.
My Tannoy Monitor HPD 385 in Tannoy Berkeley enclosure is completed. lhgin Multi-Way 0 11th May 2011 03:18 PM
Tannoy 609 compared with Tannoy 615 photomusicfreak Multi-Way 4 27th November 2008 10:27 PM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.08597 seconds (76.75% PHP - 23.25% MySQL) with 10 queries
