Introduction to designing crossovers without measurement
Old 13th April 2018, 06:21 AM   #611
Lex vs Kingpin is offline Lex vs Kingpin  Turkey
Originally Posted by AllenB View Post
The power rating of resistors should be high enough that they are not damaged by heat. It is not simple to predict how much you need. Low efficiency drivers, and woofers, and when used at high power, need to be larger than high efficiency drivers, and tweeters, and when used at low power. The resistors I use typically vary between 1/4W and 20W. It is OK to use a resistor with a higher power rating than you need. It can be useful to have a stock of 5W resistors of different values to use. When you use them on a woofer, it is best to play music through them then feel them. If you cannot keep your finger on them then you need to be using a higher rated part.
If your tweeter impedance is smooth enough to work with then you don't need the parallel resistor.
Thank you sir! I will continue the calculations. Best.
Introduction to designing crossovers without measurementHide this!Advertise here!
WinSpeakerz vs others for measurement & crossovers rick57 Multi-Way 8 12th December 2010 10:20 PM
Designing crossovers using Vidsonix Virtual Crossover triode4 Multi-Way 0 28th October 2007 01:22 AM
A brief introduction WayneM Introductions 7 30th April 2005 01:23 AM
Designing passive tri-mode crossovers? Datoyminaytah Multi-Way 9 4th September 2004 12:33 PM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 11:46 AM
