Introduction to designing crossovers without measurement
Old 6th September 2017, 01:12 PM   #561
AllenB is offline AllenB  Australia
It looks like you have 1.6uF plastic film capacitors. These are generally long lived devices and may be OK. MKT indicates polyethylene, and when faced with the choice many would prefer polypropylene (MKP, FKP). The difference, if any, will be small.
Old 6th September 2017, 09:35 PM   #562
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
I'm pretty sure MKT is polyester.
Am I wrong?
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 7th September 2017, 03:14 AM   #563
Polyethylene teraphthalate, if my memory serves is also known as polyester.
Old 7th September 2017, 09:46 AM   #564
wolf_teeth's Avatar
Of course- that is indeed accurate.
Wolf
Old 15th September 2017, 02:12 PM   #565
Tom1957 is offline Tom1957
Thank you, guys. Actually, in the meantime, I have found out what it really is. MKT 1.60 is an old marking for today's MKT 100 line of polyester capacitors produced by Sharma. The capacitance is 10 uF, 10%. I finally got hold of a LRC tester. It seems to work fine, but I'll still replace it by a ClarityCap polypropylene.
Old 16th September 2017, 05:02 AM   #566
Good find Tom, hope you weren't led astray. Component value markings can sometimes be cryptic especially the older they are. Clarity caps will do well.
Old 27th September 2017, 12:06 PM   #567
thewineguy is offline thewineguy  Australia
Thanks for all the info. I have been doing a ton of reading and this is by far the best, clearest and easiest to understand for a new comer to the crossover world. However I still would like some guidance on how this is all finally hooked up together after calculations. Is there somewhere I should look? Something about the basics getting this all working correctly together? Any help would be appreciated.
Old 22nd October 2017, 03:07 PM   #568
MITsound is offline MITsound  Canada
MITsound's Avatar
Hello, I've finalized my crossover components.
These are for a 7 watt set feeding highish (@100 db/watt home made 3 way Onken style speakers.
I was given some fancy ohno 20 gauge solid wire; is this thick enough, to wire the parts together, for the small amount of power the crossover will be passing?
"Aim above morality. Be not simply good; be good for something." HD Thoreau
Old 23rd October 2017, 07:19 AM   #569
Yes, it should survive the heat. On the other hand solid wire isn't very resilient to vibration so if you decide use it, fasten it to take the weight off the speaker connector and leave a little looseness there, using gentle bends to face the connector.
Old 24th October 2017, 01:42 AM   #570
MITsound's Avatar
Thanks. These will be outboard crossovers, terminated at input and output with binding posts. You make an interesting point about vibration I have never considered.
I have some ancient isobearings, made of sorbothane. Now I plan to pass each solid core wire through a chunk of these. Don't know how much, if any, vibration makes it to the crossover components, or amplifier, from the speaker drivers along the wire, but it must be harmless to damp it, more than not at all.
Introduction to designing crossovers without measurementHide this!Advertise here!
WinSpeakerz vs others for measurement & crossovers rick57 Multi-Way 8 12th December 2010 10:20 PM
Designing crossovers using Vidsonix Virtual Crossover triode4 Multi-Way 0 28th October 2007 01:22 AM
A brief introduction WayneM Introductions 7 30th April 2005 01:23 AM
Designing passive tri-mode crossovers? Datoyminaytah Multi-Way 9 4th September 2004 12:33 PM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 11:46 AM
