Old 26th May 2011, 01:44 PM   #1
Default my new diy speakers project
hello,
I had made many loudspeakers before. this is my new project. 3 way loudspeakers with seas excel drivers.(w26fx001,w15ch001,t29cf002) They are not completed yet. I have almost made the enclosures. they are made from polyester fiber, plywood and MDF. The crossover will be inside the granite base (not on the photos). I have spent about 6 months on it by now. I will update this post when i 'll have completed the speakers.What do you think?
Old 26th May 2011, 01:52 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Is this really new? Because I've seen another "nautilus clone" that looked nearly identical, also using Seas Excel.
But whatever, that's a heck of a lot of work for the cabs, hope they sound as cool as they look. Be sure to cover the tweeter faceplate in thick felt as it looks like you're using a worst-case diffraction scenario for the tweeter (the other drivers should be okay, especially the woofer)
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 26th May 2011, 01:58 PM   #3
hi,
yes there are also other people that maked this project. What do you mean worse case scenario for the tweeter?
Old 26th May 2011, 02:05 PM   #4
hi
can you be more specific about the thick felt please. What do you suggest to do?
Old 26th May 2011, 05:16 PM   #5
That's beautiful work. I would love to see some build pictures.
Old 26th May 2011, 07:13 PM   #6
Custom Title
badman's Avatar
Note how in the B&W Nautilus, the drivers are large relative to their mounting surfaces, as it is with your woofer, where there's a minimum of "Baffle". A circular baffle has the same distance from the diaphragm to the edge at every point on the circumference, so you get one very heavy diffraction mode. There's quite a bit of documentation on the effects of surface mounting vs. flush-mounting dome tweeters, you can consider this as a worse version of surface mounting. By using felt, you absorb the energy that illuminates this edge, so there's a largely reduced amount of energy to excite the diffraction modes. This also helps reduce off-axis energy somewhat in the crossover range to the mid, which is a good thing in this and most cases.
Old 26th May 2011, 08:44 PM   #7
here are some build pictures. Many thanks Badman for the explanations.
Old 26th May 2011, 09:38 PM   #8
Custom Title
badman's Avatar
wow, very slick, the build is even more impressive than the result
Old 26th May 2011, 10:01 PM   #9
tuxedocivic's Avatar
Unreal!
Old 28th May 2011, 11:53 AM   #10
do you think that i must use damping material? in the midrange cabin maybe? Other 2 people that i know (who made these speakers) did not use any damping material. What is yours opinion?
Qestions about my next project. (x.1, decoder, diy speakers) ic4ru5 Chip Amps 4 11th May 2010 06:24 PM
My first DIY project: Convert small Yamaha speakers to … cive1em Multi-Way 9 9th July 2009 03:36 PM
my first DIY speakers project Thebrain Multi-Way 22 16th May 2009 09:40 AM
Suggestion needed to match speakers for DIY project safetyman Multi-Way 0 29th January 2004 06:05 PM
Page generated in 0.10576 seconds (76.29% PHP - 23.71% MySQL) with 11 queries
