I'm designing a midbass tractrix horn using a B&C 12PE32 driver. I need to design the crossover for it also, of course. I've looked at some reference material and I can't seem to find out how the horn affects the driver's impedance curve as provided by the manufacturer. Maybe it doesn't affect it all. Obviously, I need this information in order to design a proper crossover. The back chamber will be sealed, so I won't have the two impedance peaks of a vented enclosure. Do the different horn expansion shapes have different effects on the driver impedance?
I also need to design better crossovers for my midrange and tweeter horns. I just bought the DE10 with matching ME10 tweeter horn. I have an Edgar tractrix midrange horn for the Dynaudio D54 driver. Thanks in advance for any help. |
#2 |
Model in Hornresp and you'll get to see the Z curve as one option.
#3 |
As unfortunate as it may seem, measuring it is your best bet, but it really isn't that hard. It takes a couple of resistors, some clip leads and a computer.
#4 |
OK, thanks. I did that, and this B&C driver on a 1/4 size 60 Hz tractrix horn still shows the typical rising impedance with frequency due to voice coil inductance, and the peak at Fs as well. So, in order to design a passive crossover, I still need to install compensation filters also.
#5 | |
I'm also wondering how the driver's resonance affects the frequency response near the horn's cutoff frequency. Particularly on a tractrix flare. If tractrix horns are particularly sensitive to this, then that may explain the poor bass performance people have reported for them. |
#6 |
#7 |
You need to know the impedance of all your drivers at all frequencies, not just the crossover frequencies, just like you need to know the frequency responses of the drivers in the cabinet. Measuring all this is the only way to go. Simulation is to get you something close to what you want to work with. Then you design and build your cabinet, build it and measure the drivers in it. Then you design a crossover.
#8 |
#9 | |
#10 |
For what it's worth, if you were designing without measuring and created an impedance rise compensation filter based on the raw impedance, I doubt it would change much in the box and I'd leave it at that.
| How To Increase Driver Nominal Impedance? | Jay | Multi-Way | 11 | 26th April 2011 06:33 PM |
| Short bass horn - impedance vs distortion | deiksac | Subwoofers | 0 | 23rd November 2010 11:21 PM |
| How to measure impedance of driver? | lgreen | Multi-Way | 1 | 30th January 2010 05:34 PM |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 01:24 AM |
| Driver Impedance/Matching | NTSBuilding | Multi-Way | 7 | 13th September 2008 05:53 AM |
| Page generated in 0.10433 seconds (82.25% PHP - 17.75% MySQL) with 10 queries |
