Woofer = Eton 11-581
Current mids = 1 Scanspeak 18w-8545 one usher 8945 Tweeter = Newform Research Oval 30 Speakers are triamped with Behringer DCX 2496 so any adjustment can be made. Woofers are in seperate L enclosures, currently ported but speeding things up by converting to sealed is on my mind. Mid cabs are partially built to be +/- 45L but I can fill as necessary if I need to reduce volume. I'm waiting on baffles. The current midwoofer setup drives me a bit nuts due to the different drivers. The Ushers (at least I belive they are) were bought from ebay and supposed to be Scanspeaks. They were just relabelled I believe. Before I go out and buy another matching pair I wanted to start this thread in case you more knowlegeable people had some suggestions. Thank you Kevin |
#2 |
The perfect range for Seas Excel W22.
| 12' / 30cm Woofer in BL-Horn up to 1500Hz? | Drrum | Multi-Way | 0 | 25th March 2011 01:36 PM |
| Driver selection for 3way Studio Monitor? | rhythmdiy | Multi-Way | 13 | 1st August 2008 10:00 AM |
| Tweeter 95dB eff and from 1500Hz x-over anyone? | Cordraconis | Multi-Way | 5 | 27th June 2008 03:33 PM |
| Best amp for >1500Hz? | Khron | Chip Amps | 7 | 19th May 2006 07:35 AM |
| Are dipoles better (40 – 1500Hz)? What’s the most important? | rick57 | Multi-Way | 41 | 5th December 2004 04:02 PM |
| Page generated in 0.06039 seconds (72.58% PHP - 27.42% MySQL) with 10 queries |
