Hello, I have a pair of Polk R30 floor standing speakers. They look great and sound terrible. Rather then replace the drivers with more Polk drivers I would like to replace them with Klipsch drivers. I am being told I must use a box calculator to see which drivers I need to use. I CANT understand how to use the box calc. I am hoping I will be able to use the drivers from the RF 62 2 floor standing speakers. Can anyone PLEASE help me out here?
#2 |
measure the internal box volume of the Klipsch speaker and measure the internal volume of your polk cabinet. if they are the same just swap drivers networks and vents. If they are within 20 % don't worry about making any other changes as it won't make a big enough difference to bother. If the polk cabinet is larger reduce the internal with a sand bag or styrofoam anything to take up the unwanted volume. If the polk cabinet is smaller then stuff with some Dacron fiber fill which can give you as much as a 20 % increase in volume. That should do you. You don't need to learn to use a box calculator just balance things up and keep the ports the same. If thepolk cabinet is a lot larger you might try installing the Klipsch woofer and run it closed box as you might like it better and it will save you a lot of work. If that is the case just try it out you have nothing to lose as many folks prefer sealed cabinets over reflex as a sealed box rolls off more slowly and keeps better control over the driver. Make sure the cabinet is air tight what ever you do. Hope that helps. Get going your time is running out. Best regards Moray James.
moray james |
#3 |
We need more information.
Are both cabinets vented or sealed? A driver that is good for a vented cabinet may nor be suited for a sealed cabinet and vice versa. Are you hoping a Klipsch driver will sound better than a Polk driver? Or are you just scrounging parts? |
#4 |
Without modifying the whole crossover, you can't just drop in drivers from one speaker into another...
The matter of box tuning and bass damping is not even the first issue (though of course it's still a big one) I highly recommend building a speaker from scratch. Perhaps this one: Zaph|Audio Last edited by RockLeeEV; 21st May 2011 at 09:22 PM. |
#5 |
Hey everyone,
Moray, How did you know my time is running out? It is indeed because I go back to work at the end of this month. Just curious why you made that statement? The Polk cabinet is considerably smaller. It is rouchly 34 Inches tall, 9 Inches deep and 8 inches wide. I believe that gives it a volume of 2448 Cubic Units. The Klipsch cabinet is 40 Inches tall, 15 Inches deep and 8.5 Inches wide. Which is 5100 Cubic Units. The other difference is that there are two woofers in the Klipsch speaker as well as two ports. There is only 1 woofer in the polk Cabinet and one woofer. There are also no dividers in the polk cabinet and I am not certain if there are in the Klipsch or not. R30 Specs Page : Two-way floor-standing loudspeaker : Polk Audio RF-62 II Floorstanding Speaker - Specifications |
#6 |
With Tarragon, Is the info I provided previously enough or am I leaving something out? Yes I am hoping the Klipsch drivers will sound substantially better then the Polks. I am a huge Klipsch fan but I like the look of these cabinets and thought this might be a cool project.
RockLeeEV, Couldn't I just use the same cross over from the Klipsch drivers in the Polk cabinet or does it not work that way? The Klipsch had 2 woofers so If I were to use that crossover would I have to add another woofer in this cabinet? If so wouldn't I have to do it in a sealed area in the bottom of the cabinet? Perhaps a down firing woofer? Just throwing an idea out there... |
#7 | |
I would try and get the T/S parameters for these drivers and then pick up a copy of a speaker building book (eg, Weems or whatever). Read the book, search the threads and then start asking questions. Last edited by WithTarragon; 23rd May 2011 at 10:59 PM. Reason: .. |
#8 | |
a) want to use the klipsch crossover in the polk cabinet with the klipsch drivers b) want to use the polk crossover in the polk cabinet with the klipsch drivers I don't see either working to be honest. Here's some links you may wish to read FWIW crossovers Aperion University - Crossover Design & Theory - Aperion Audio |
#9 | |
moray james |
#10 |
Well, What I have is 2 Klipsch Tweeter/Tractrix horns. They came from an other speaker entirely but I put them in the Polk cabinets and they sound MUCH better then the Polks ever did. Even on the same crossover. I have 3 Klipsch RF62 Woofers but no cabinet for them. If this set up sounds good then I will try and find something to do with the third woofer.
Can someone explain something to me? What is a Midbass? I would assume it is exactly what it sounds like but I have heard the Klipsch RF62 drivers called woofers & Mid basses. |
| polk plate amp and 8 Klipsch drivers....what to do??? | jmillerdoc | Subwoofers | 9 | 18th May 2010 07:26 AM |
| Just acquired a pantload of replacement drivers for Energy, Polk, Klipsch | The Paulinator | Swap Meet | 7 | 2nd October 2009 05:46 PM |
| polk componets. | skooter | Car Audio | 1 | 29th August 2008 10:32 PM |
| Polk Audio Sub? | samsagaz | Subwoofers | 4 | 22nd January 2007 02:51 PM |
| Polk Sub ??????? | ralph-bway | Subwoofers | 1 | 20th October 2005 12:39 AM |
| Page generated in 0.12613 seconds (82.56% PHP - 17.44% MySQL) with 10 queries |
