I was wondering how do i calculate the new efficiency for 4 identical drivers connected in 2s2p, if each of the drivers are 8ohm 90db/watt? What about 16 drivers in 2s2p clusters of 2s2p still maintaining 8 ohm overall? Is there a systematic way to calculate the new efficiency? Thanks. |
#2 |
3db more efficiency each time you double the cone area. The load doesnt matter. so 4 speakers will put out 6 db more using the same amount of watts. 8 speakers would be 9db, 16 speakers would be 12db...
#3 |
Make it more complicated: 9 speakers arranged 3s3p?
Staying with baseline 90db/1W per individual speaker. 99.5424250943932487459005580651023db / 1W ? figuring: 90 + ( 10 * LogBase10 ( nospeakers ) ) Last edited by kenpeter; 21st May 2011 at 12:42 PM. |
#4 |
Thanks for the info!
#5 |
And stringing an array is further complicated that each driver's impedance
is affected by neighbors, reflections from the floor, and lack of neighbor. Putting them all in parallel makes all the cones move (expressed in voltage) equally regardless cone backpressure (expressed in current). But you can't realistically wire all 16 in parallel or the impedance becomes too low. Any wired in series have to be of equal impedance and cone load, else the lesser loaded cones will move further (and drop unequal voltage) w. series current. Since its probably 4x4 sitting on the floor, you got 6 speakers that will see 8 neighbors or reflections. 8 speakers that see 6 neighbors or reflections, and 2 speakers at the top corners that see only 3 neighbors. How you wire that? I'm thinking 16 small individual amplifiers might be the more practical answer... Assuming horizontal symmetry you aren't too near a wall, maybe 8 would do. Last edited by kenpeter; 21st May 2011 at 01:09 PM. |
#6 |
Kenpeter,
I did think about the boundary effects, i will probably have mine in a 2x2, should be less than the theoretical 6dB gain. In my case, the lower 2 drivers will 'see' the floor more than the others, but i'm not sure if that has enough impact to affect the electrical loading parameters. |
#7 | |
The Fs will lower slightly. As an example, a single EVX-150 has a Fs of 35 Hz, two in close proximity 34 Hz, and four drops it to 32.5 Hz. |
#8 |
rhapsodee,
Use this calculator that handles 2 drivers at a time: See Room Response Calculator v0.6d link here below but it's easy to estimate/calculate the boundary gain for any numbers of drivers by using this graph: See the picture: http://www.rsu.edu.ru/~foboss/hi-fi/...c/room060d.xls b |
#9 | |
Wire your floor speakers in one horizontal series string. Wire top speakers in the other horizontal series string. Parallel these two strings vertically back to 8 ohms... Top and bottom strings are NOT same impedance or current. But wired in parallel, all cones should move the same due to equal voltage on every speaker. Theoretically, maybe, if... Paradox that electric pressure (electromotive force) equates to mechanical movement, and electrical movement (current) equates to mechanical pressure. Somehow roles get swapped. Magnetism, go figure... I suppose its equally valid for all cones to see equal current and pressure at different voltages and velocitys. But lighter loaded cones might then exceed xmax earlier than the rest. And that would limit the entire array. Last edited by kenpeter; 21st May 2011 at 05:04 PM. |
#10 |
I have now some test boxes with the same problem
| amplifier works connected to PC .. but not when connected to car radio | anwaypasible | Analog Line Level | 1 | 2nd March 2011 07:42 PM |
| Combined Topology - Thoughts? | buzz1167 | Solid State | 32 | 19th September 2010 07:40 AM |
| OB efficiency with 2 or 4 woofers | tinitus | Multi-Way | 29 | 19th June 2008 12:09 PM |
| Zobel and notch combined | Klimon | Full Range | 2 | 4th September 2006 12:05 AM |
| Any high efficiency woofers that are NOT made from paper??? | sardonx | Multi-Way | 6 | 13th August 2005 07:24 PM |
| Page generated in 0.10291 seconds (81.67% PHP - 18.33% MySQL) with 11 queries |
