Im starting To design a TM 2 way active speaker for 2 channel music and home theatre mains. The woofer will be a Aurum Cantus AC-250F1 10" Woofer. I cant decide what HF driver I should use. Either the Dayton Audio RS28F-4 silk dome or the Eminence PSD:2002S-8 Titanium Driver with a 90x 60 wave-guide. What would give me the best sound quality? thanks
#2 |
frugal-phile(tm)
With a 10" woofer you are likely going to need to XO low. The waveguide, or a good mid-tweeter (with XO <400 Hz) is your best bet.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
if the waveguide is anything lke the celestion one i have, which is 90°x60° ellipical, then the waveguide probably wont be much use at 400Hz either. If i misunderstood your description then ignore what i wrote!
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone. |
#4 |
frugal-phile(tm)
I'd expect a waveguide to be XOed at about 1000 Hz. The mid-tweeter approach would warrant an XO <400 Hz.
dave
#5 |
Running a 10" up to 1000Hz should be no trouble with the right driver, and running high like that (or even higher) would be favourable as far as the conventional waveguide approach is concerned.
#6 | |
Agreed again. even though the cut off for my waveguide/horn , is somewhat higher than 1k, i think its primarily for a compression driver, and states 3k F3. is the waveguide 60x90° or 60x90cm...confused....im not waveguide expert, but isnt 1k too low for this waveguide? EVEN if the compression drivers Fs is LOW. Id favour the midtweeter approach, although the waveguide is understandably a tempting idea.
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone. Last edited by mondogenerator; 20th May 2011 at 05:16 AM. |
#7 | |
The waveguide is 60x90°, the woofer is good to about 2k. I was thinking of crossing over at 1.6k(ish) the f3 in unibox is 29hz in a 70liter box. what would the overall sound quality difference be between the two types? |
#8 |
No soft domes for WG . Pressure in the vicinity of the cone is not the same as in direct radiation .
#9 |
#10 |
What about something like the big Hi-vi planar tweeter with WG ,the RT2H - ?!?
| 99db dome tweeter without titan and without horn ? | tiefbassuebertr | Multi-Way | 41 | 1st March 2012 10:52 AM |
| Horn loaded dome midrange | Defo | Multi-Way | 48 | 11th March 2010 11:16 PM |
| Horn for dome tweeter | Hylle | Multi-Way | 21 | 22nd October 2009 01:26 PM |
| MTM Horn vs Dome for the T | Robh3606 | Multi-Way | 0 | 20th August 2007 03:55 AM |
| Page generated in 0.09162 seconds (81.75% PHP - 18.25% MySQL) with 10 queries |
