Old 20th May 2011, 02:13 AM   #1
Default Tricky situation
Hey everybody, I have a bit of a dilemma here. I recently purchased a pair of Cerwin Vega D-7's on craigslist. The original 122w2 woofers have been replaced with goldwood 1248 woofers, which I knew going into the purchase, not thinking it was that big of a deal. However, when I tested them when I got back home, it would seem that while the woofers do indeed work, they are pretty quite when compared to the midrange and tweeters. They are also quieter than my Cerwin Vega DX3's, which definitely shouldnt happen. They are both 8 ohm impedence, so that isnt the problem. Anyone wanna help me out?
Old 20th May 2011, 02:18 AM   #2
Speakerholic
Cal Weldon's Avatar
What sort of help are you looking for? Sounds like the Goldwoods are less sensitive so you will need to EQ some bass in there if you want to keep the woofers or add padding to the mids and highs. Remeber. Cerwin Vega's were all about volume not quality so you may have to get CV woofers.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
help plsssss...............1 more situation i have here victorioarvin Subwoofers 0 20th July 2008 01:04 PM
Tricky CA21REX question Daze Full Range 0 7th March 2008 07:16 PM
best of a bad situation bobtrancho Multi-Way 10 22nd August 2007 07:29 PM
A tricky question from a novice msharpe Multi-Way 14 28th May 2006 06:41 AM
More situation description jlg4104 Tubes / Valves 1 2nd December 2002 02:13 PM
Page generated in 0.06118 seconds (68.77% PHP - 31.23% MySQL) with 10 queries
