Old 19th May 2011, 09:35 PM   #1
Hsmeets is offline Hsmeets  Netherlands
Default Pro-re-ject #1
Planning to built a pair of speakers. Full spectrum sound, good imaging, enough dynamic reserves. Plan to run these semi-active as I own a Lyngdorf system. Peerless XXLS 10" woofer in a closed box (qtc at 0.707) and using room gain, boundary effect and Lyngdorfs Roomperfect to get well controled bass that extends into the cellar Active X-over at 200Hz, passive x-over somewere around 2 to 3Khz. Have not really made my mind up about mid & tweet, just too many choices.
Any thoughts about easy to filter mid-woofers that still have a good polar response at 2Khz.
Cheers
Huib.
Old 19th May 2011, 11:08 PM   #2
ttan98 is offline ttan98  Australia
For the side mounted woofer the x-over frequency should be less than 200Hz, more likely to be about 100Hz the most is 120Hz.
My experience is that your OB mid-woofer will NOT go down flat to 200Hz, so 100Hz is impossible, unless you heavily equalized it using DSP.
Old 20th May 2011, 09:10 AM   #3
It's not an Open Baffle.
It's a regular box design but because the Woofer doesn't needs a huge cabinet I slimmed it down to make it optically as lean as possible (WAF). The small top cabinet is what normally would be the mid chamber within the bigger cabinet.
Huib
Pro-ject turntable motor ksporry Analogue Source 3 31st January 2010 04:19 PM
pro-ject tube box Stefanoo Tubes / Valves 4 20th September 2008 09:32 PM
Linn or Pro-Ject??? Triumph Analogue Source 2 17th January 2006 06:39 AM
Pro-ject 1.2 Vs Rega P? kazoo Analogue Source 5 1st July 2005 02:49 PM
Pro-Ject 1 Xpression help JRKO Analogue Source 15 18th November 2004 10:06 AM
Page generated in 0.06598 seconds (69.00% PHP - 31.00% MySQL) with 11 queries
