Old 19th May 2011, 04:58 PM   #1
Default First build/computer speakers
Ok so this is my first build and I am hoping you guys could give me some feed back. I am making amall speakers for use on my computer or with my zune. This is what I was looking at so far.
mid
HiVi M4N 4" Aluminum/Magnesium Midbass
tweeter
HiVi TN28 Fabric Dome Tweeter
crossover
Dayton Audio XO2W-3K 2-Way Crossover 3,000 Hz
I will build a sealed square enclosure with the tweeter mounting on top.
Probably going to power it with this
Lepai Tripath TA2020 Class-T Hi-Fi Audio Amplifier
will this make a decent setup? Or am I missing something?
Old 19th May 2011, 05:16 PM   #2
frugal-phile(tm)
planet10's Avatar
You are going to get piled on for suggesting the use of an off-the-shelf generic XO. The XO is the weakest part of a speaker, and it really needs to be specifically designed for the drivers/box.
Given the application, why not toss the XO completely and go 1-way. Much fewer issues near field. For your budget, there is quite a selection of good FRs. And knowing that tweeter, with better HF. My personal 1st choice would be CSS/Mark Audio EL70.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th May 2011, 05:17 PM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
dave
looks like a complicated setup / xo for sure !!
Old 19th May 2011, 05:19 PM   #4
frugal-phile(tm)
planet10's Avatar
PS: there are a number of threads on this same subject. Comments & suggestions already made will give you a good grounding.
dave
Old 20th May 2011, 11:10 AM   #5
So if I goto a single full range driver should I put any type of filter on it? Also can you give advice on any from parts express as I want to order from tere because there are other items I am also getting from there would rather just order from one place.
Old 21st May 2011, 06:27 PM   #6
wolf_teeth's Avatar
Default Yeah- you won't like them as you plan....
The M4N has 2 breakup peaks that need to be dealt with, and the TN28 is probably not robust enough to meet it where it is required to xover. I used the TN25 with the M4N in my Sophomores, and I think they are incredible little speakers.
Sophomores pictures by wolf_teeth_speaker - Photobucket
If you look at my signature here, I have it linked to my profile elsewhere with the writeup.
If you want a 2-way, I recommend building a proven design first, like the above^^.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 21st May 2011, 06:38 PM   #7
katana2112's Avatar
Those are GREAT looking Wolf!
Aggressively Passive
Old 21st May 2011, 06:42 PM   #8
trondareo's Avatar
I second the use of a full range. Depending on the unit, baffle difraction and box you might introduce a filter at a later time to attenuate some bump in the freq curve. Lacking a masurement mic, this is best done by listening. I suggest you use a digital equaliser to play with the sound until you find something that works. I like Blue Cat Audios Tripple EQ.
I´m doing stuff at http://taooftubes.blogspot.com/
Old 21st May 2011, 06:59 PM   #9
wolf_teeth's Avatar
Thank you!
Wolf
Link to other profile:
Old 21st May 2011, 07:18 PM   #10
frugal-phile(tm)
planet10's Avatar
Whether you need a filter or not is driver/box/room dependent.
I have yet to get any FRs i like from PE (this is th enext one i'm going to try), but some of the other Tangbands, and the house brand RS100 (?) get good reviews.
dave
Speakers for small bedroom??? Studio Monitors vs Computer Speakers? matthughes64 Full Range 4 16th May 2011 10:32 PM
Advice on computer speaker build bobsagat666 Full Range 4 28th March 2011 11:43 PM
Computer speakers doors666 Full Range 35 15th December 2010 02:42 AM
looking to build some computer speakers grinder Multi-Way 3 18th January 2005 05:24 PM
My new computer speakers fivaxis Multi-Way 3 22nd March 2004 07:26 PM
Page generated in 0.12937 seconds (84.28% PHP - 15.72% MySQL) with 10 queries
