Hi all,
See this measurement: ![]() That's on axis at 1m. The rising top end was deliberate as I listen off axis and I'll be padding the tweeter down a couple db and remeasure. Here is the in-room, in position measurement smoothed 1/6th. Blue line. Red is in position @ 1m on axis: ![]() Here is a nearfield measurement of the woofer: ![]() My question is with respect to the 5-6db dip through 2 - 3khz. It's not that audible, but annoys me that it's measured that way, and as this is my very first from scratch XO design, I wanna learn. I don't really see it on the in room measurements. Is it a phase issue? Are the LP and HP to far apart? Is the gating causing some kind of anomaly? Any help is appreciated. Thanks. |
#2 |
You said that you allowed the rise on axis as you planned to listen off axis. I assume that the dip is not there off axis. Your in room response may be showing this as it includes reflected off axis sound.
#3 |
it could be
how does it look if you reverse polarity on tweeter the expert guys says that when design is right you will have a 'deep null' at xo point, with wrong polarity on tweeter its my understanding that they use it to check correct function well, in my book a good speaker is made for on axis listening to me, off axis sounds, ehh....off |
#4 | |
It shows very much like a null, but, polarity is very right, from output graph above. Could be a null from the angle with the tweeter (not phase issue) of from the mid/woofer only (nearfield measurement of the woofer). Doesn't show like a "practical" problem. Last edited by Inductor; 19th May 2011 at 11:36 AM. |
#5 |
Hi guys again, and thanks for the thoughts.
So I was resisting reversing polarity because I had it all soldered up already :P But I did anyways. This is what I got: ![]() So it looks like that corrected it. Having said that, I did have two 2ohm resistors paralleled together in series with the tweeter, and snipped one out at the same time as flipping the polarity. The tweeter level seems better now. And I don't think that would have played much into making that look flatter. My model in PCD says the null should be deep, but that's just a model and I'm new to measureing. I somewhat wonder if I didn't screw up my measurements. I did compare them to zaphs with similar results. So... was this a polarity thing after all? Is the XO not very good? |
#6 |
Oh and I almost forgot, I did this measurement in position unfortunately due to time. So there are early reflections, hence the huge amount of gating. The red is my last measurement from my OP for comparison, but I gated it the same as the blue for a fair comparison.
#7 |
I think you need to do more tests.
Measure the drivers with and without xovers, tweeter at 1m, woofer n/f Then you can see if your xovers are acheiving the desired filtering acoustically. With drivers of equal ampiltude output, and correct filtering, a good reverse null (say of 20db or so ) can be seen. |
| What is the Best 2way speaker | msj965 | Multi-Way | 32 | 5th June 2010 08:02 PM |
| how to? simple wow/flutter measurement | Steerpike | Analog Line Level | 14 | 27th September 2008 07:45 PM |
| 10liter... 2way... help... | gcm908 | Multi-Way | 6 | 15th November 2004 04:35 AM |
| Seas 2Way. | Baronty | Multi-Way | 10 | 20th October 2004 07:24 AM |
| Page generated in 0.09294 seconds (82.25% PHP - 17.75% MySQL) with 10 queries |
