Old 18th May 2011, 05:01 PM   #1
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Default Kugelwellen Horn.
Hi Today I received a set of Kugelwellen horns.
I have a 2inch driver a Paudio (400Hz)horn and now the KH55 (250Hz) Kugelwellen. I bolted it on and listened with the first sound I could here the open smooth sound of the horn Yes it appears that this will give a great combo together.
My measurement gear stands in my livingroom because I am experimenting a lot with the passive filter.
So direct a MLS measurement done What a smooth response and what a nice top end I can easily correct a bit with a RC filter.
File Type: jpg Schermafbeelding 2011-05-18 om 18.39.17.jpg (22.3 KB, 635 views)
File Type: jpg Schermafbeelding 2011-05-18 om 18.39.00.jpg (36.1 KB, 665 views)
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 18th May 2011, 05:33 PM   #2
Helmuth's Avatar
Here a user who made a film of the horn. Even then you can here the open sound of the horn listen.
YouTube - Tube amp - se kt88, jbl 2226, altec 288
Old 18th May 2011, 05:55 PM   #3
Helmuth's Avatar
I was planning to make tractrix horns my self I could not done better my self and even the cost for parts would come to the same cost of these horns with professional finish an aluminum adapter I am very pleased with the quality.
File Type: jpg Schermafbeelding 2011-05-18 om 19.59.45.jpg (13.3 KB, 112 views)
File Type: jpg Schermafbeelding 2011-05-18 om 19.59.59.jpg (50.7 KB, 106 views)
Old 18th May 2011, 06:08 PM   #4
ra7 is offline ra7  United States
where did you buy these from?
Old 18th May 2011, 06:11 PM   #5
Helmuth's Avatar
Ebay search kh55 or kh75 or JABO. The manufacturer of the horn sells them.
Old 18th May 2011, 06:42 PM   #6
Thanks! I'll check it out. I'm building some paper horns with my friend John (inlowsound.com). Can't wait to see how they turn out.
In your first post, the step response is not very clean. Is that ringing we are seeing?
Old 18th May 2011, 07:52 PM   #7
Helmuth's Avatar
The driver has a titanium dome it is often seen with that kind of diaphragm. Although it changes with position of the microphone and my more professional HBX V6 mls program.
Measured without any correction or filter direct connected to my reverence hypexclass-d amplifier.
You see unbelievable flat response from 550Hz up to 9kHz them it needs a snubber looks like some breakup.
first : response with blackman and 1/3 smoothing
Second : response without any kind of smoothing raw measuring points.
thirt : stepresponse
Last : MLSimpulse all measured about 0,5mtr away from horn mouth center.
Old 18th May 2011, 11:07 PM   #8
norman bates's Avatar
how's the dispersion ?
Old 18th May 2011, 11:18 PM   #9
limono is offline limono  United States
I have the same horns bolted to TAD TD-4001 (400Hz) and I like the combo quite a bit , much more that 340Hz Dr. Edgar tractrix. To be honest Edgar himself didn't like Tad on his horn either .It is not tractrix though but exponential (jabo) and I was informed that the cut off is 320 Hz not 250.
Old 19th May 2011, 07:53 AM   #10
Jmmlc is offline Jmmlc  France
Hello Helmuth,
Nice horn.
Too bad it is a bit too much truncated at the mouth!
See a complete kugelwellen profile in the attached graph.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 7 21st March 2010 05:31 PM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
Page generated in 0.11427 seconds (86.52% PHP - 13.48% MySQL) with 11 queries
