Old 18th May 2011, 11:54 AM   #1
Greg M is offline Greg M  United States
Greg M's Avatar
Default Highpass Filter Help Needed
I have a 16 ohm horn I would like to build a highpass filter for.
800hz with 12db roll off.
All the design discussion I have seen never seem to go above 8 ohms?
I have a tube stereo amp (35w per ch) and would like to run one channel to the woofer and one to the horn. It would give me the advantage of being able to set the output transformer according to the ohm load of the speaker (should I get experimental)
Anyway need help with a 16ohm 800hz 12 db high pass filter.
PS
I'd buy one if I could find one
Old 18th May 2011, 04:12 PM   #2
AllenB is offline AllenB  Australia
The short answer would be to simply halve the capacitor and double the inductor values obtained from assuming the driver were 8 ohms.
Old 18th May 2011, 04:19 PM   #3
Greg M's Avatar
Using the online calculator HERE
I came up with a couple values for components for a highpass filter for the 16 ohm driver. Wanted to run this by anyone that had a bit more experience than I do with this type of thing
Linkwitz-Riley type xovr
16 ohm driver
821hz crossover point
C1 = 6.06 µF
L1 = 6.203 mH
I fiddled with the crossover point to get the component values close to some off the shelf values.
Do these values sound reasonable?
Old 18th May 2011, 04:40 PM   #4
Yes, they are exactly what you are asking for. They might work for your horn.
Old 18th May 2011, 05:57 PM   #5
Greg M's Avatar
As long as my overly expensive, no longer made driver doesn't go poof! I'm happy
Old 19th May 2011, 11:20 AM   #6
Inductor's Avatar
You should need some attenuation on the horn too (usually needed), or at the pre-stage.
Breadboard amp = echoes + highpass filter? dopeydavoid Solid State 2 12th April 2011 12:50 PM
Highpass filter via feedback cap scottw Chip Amps 12 24th October 2009 11:20 AM
Active highpass filter - ground skogs Analog Line Level 3 19th June 2007 06:25 PM
Measuring tweeter FR without a highpass filter owdi Multi-Way 3 14th March 2007 05:40 AM
Highpass filter using sound card??? vsboxerboy Digital Source 0 18th July 2005 08:59 AM
Page generated in 0.08195 seconds (74.39% PHP - 25.61% MySQL) with 10 queries
