Old 17th May 2011, 04:56 PM   #1
Default Clones - Chipboard or MDF?
I am cloneing a set of Audiomaster speakers & am wondering if there will be much difference if I use mdf instead of chipboard? I have made prototypes from 18mm chipboard (as per the originals) & am pleased with the results (sonically), but they are shoddy with gaps & allsorts (not good for an infinate baffle, I know - but it was just a quick test) & I would prefer to use mdf for the finished ones as it's stronger. I am making them as a floor stander instead of stand mounted as per the originals & they have a partition in them (in order to keep the same capacity) that will be filled with sand. They only have foam in at the moment - I haven't put bitumen panels in them & they sound close to the originals (obviously I will in the finished ones). Will it make much difference using mdf?
Thanks for any advice,
Colin
Old 17th May 2011, 07:45 PM   #2
it can even improove.
Linn clones? hemling Chip Amps 3 26th January 2009 04:44 PM
CAD vs. chipboard enclosure flshzug Multi-Way 0 16th February 2008 07:00 PM
Response 2.5 and 3.8 Clones R-Carpenter Multi-Way 15 14th November 2007 01:34 PM
my proac clones... Jadde Multi-Way 8 10th February 2003 08:51 PM
MDF/Sand/MDF cabinet details Petter Multi-Way 25 16th April 2002 02:10 PM
Page generated in 0.06817 seconds (69.33% PHP - 30.67% MySQL) with 10 queries
