Old 17th May 2011, 02:03 PM   #1
lduarte1973's Avatar
Default Speaker crossovers
i´m looking for a easy , good quality 2 or 3 way crossover to build that i can adapt to diferent speakers by chaging component values .
Old 18th May 2011, 04:18 AM   #2
What's your preference: active, passive or DSP?
I have some PCBs designed that have two 2-way (LP+HP times two) 2nd order active crossovers with adjustable corner frequency, Q, and input gain. You could use these in a 2- or 3- way crossover system that is reconfigurable. Adjustments are made via multi-turn cermet potentiometers, or you can use off-board panel-mount potentiometers if you would prefer.
I have had a couple of inquiries about the boards, so I may send the design out for a production run. I tested a prototype of the board and it was great. I added a few extra connections so that a notch filter can also be created.
I posted about the board previously, but have made some additions since then, so I should probably start a new thread about it.
-Charlie
Old 18th May 2011, 09:32 AM   #3
i was thinking of passive crossover , but I have other projects i want to use active too
Old 18th May 2011, 01:15 PM   #4
tinitus is offline tinitus  Europe
due to no high pass series cap on midrange its not suited for exstreme SPL
well, unless you use very tough pro midbass
with normal hifi midbass it works really well at moderate SPL
looks simple, but tricky to adjust properly
very sensitive to 'timing'
even very small adjustments can make it like 'night or day'
Old 18th May 2011, 03:19 PM   #5
can i use it with 4 ohm woofer , 8 ohm mid and 8 ohm tweeter ?
Old 18th May 2011, 08:20 PM   #6
no problem as such
values are different
but with different drivers they will be anyway
adjusted a resistor
it worked, and it didn't, fully
changed a few other resistors to make it work
and it works again, for now
just a small change to a single component
and other components will need change as well
thats how it is with this xo
but there's a trap
even if it sounds great, phase may be wrong
your ears get annoyed
or you are constantly moving your head
you will feel it in your ears when its right
its difficult, takes time and practice
and 3ways may never be perfect
I expect my speaker/xo will still need more work
Old 18th May 2011, 08:33 PM   #7
thanks
Old 18th May 2011, 11:51 PM   #8
just a short note
I changed reversed polarity on mid to reversed pol on tweeter
maybe it works better because xo is more like kind of a 2.5way
far from finished yet
but its doing something right
jingles are dissected in a funny way such that you can hear each element used to compose it
but in coherent and musical way
definately a musical monitor
and that was my goal
70's speaker drivers and crossovers worth reusing? Dejavous Multi-Way 10 29th April 2008 05:40 AM
Speaker connectors for use with external crossovers luvdunhill Multi-Way 6 2nd April 2008 12:58 AM
Loud Speaker Crossovers and power amp placement JRKO Multi-Way 20 1st August 2004 11:07 AM
biasing electrolytics in speaker crossovers? capslock Parts 3 5th August 2002 11:23 AM
Page generated in 0.09678 seconds (78.09% PHP - 21.91% MySQL) with 11 queries
