Old 16th May 2011, 10:31 PM   #1
Default first order filter 6dB down
If a standard butterwort first order filter is 3 dB down at say 800Hz, How do i calculate at which freq. it to be 6dB down?
Or more simply said: how do i calculate the -6dB point of a first order filter.
Old 16th May 2011, 10:59 PM   #2
godfrey is offline godfrey  South Africa
A low pass filter is -6dB at 1.73 times the corner frequency. (1.73 = the square root of 3)
For a high pass filter, it's the inverse i.e. -6dB at 0.577 times the corner frequency.
btw, one octave beyond the corner frequency, response is -7dB, one octave before the corner frequency, response is -1dB
Old 16th May 2011, 11:29 PM   #3
hmm, an octave is a dubbling of the frequency
The corner frequency is where the response is -3dB (is it?)
Then an octave beyond the corner freq. must be -9dB (6dB/octave)
Old 17th May 2011, 12:43 AM   #4
tinitus is offline tinitus  Europe
Linkwitz or Bessel
well, they are not 1. order, but can be made to work like it
someone have said its found somewhere in between 1. order and 2. order
but its not just the -3db or -6db that are different, the slopes are different curves too
not impossible like finding a needle in a haystack, but probably the best way to describe it
the only thing that can said with absolute certainty is that the stricktly calculated values are the ones that wont work
Old 17th May 2011, 01:00 AM   #5
Yes
Yes
No, because the corner is rounded. Here's what it looks like with a corner frequency of 1 KHz.
phase shift of second order filter bondo Multi-Way 9 8th April 2009 02:24 AM
First-Order Lowpass Filter with a Cap Taterworks Multi-Way 6 14th October 2007 01:55 PM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 04:50 PM
5th order filter chip Russ White Chip Amps 8 9th June 2005 04:19 PM
1st Order XO with -6dB XO frequency. Has anyone tried this? primalsea Multi-Way 20 28th May 2004 06:10 AM
Page generated in 0.09315 seconds (74.54% PHP - 25.46% MySQL) with 11 queries
