Okay, I know there's plenty of people out here who have done full-on constant directivity speakers with huge horns etc. And that's fine. They certainly have their place.
When I think of most speakers, commercial or DIY, I think of 1" tweeters being mated to 7 inch woofers with a crossover designed around on-axis response. But when I think of Toole's research, I can't help but think of the speakers it actually produced - things like the JBL LSR6332, Infinity Primus P363, or Revel Salon2. They really use pretty shallow waveguides in multi-way speakers... wider dispersion than an Econowave or Summa but a lot more controlled than your average typical speaker. So I guess I was jusr wondering what "Toole-style" DIY speakers exist. The ones that are coming to my mind right now are the Troels DTQWT, The various Seas DXT bookshelfs, the Zaph TMM, and that's about it. I was just wondering if anyone cares to post other such "shallow waveguide" speaker designs worth considering building. Anything out there with an elliptical waveguide? Further, anything with a fancy overpriced beryllium tweeter? Last edited by RockLeeEV; 16th May 2011 at 06:50 AM. |
#2 |
Of course, constant directivity doesn't have to be narrow directivity. It can be omnidirectional. Although such a speaker would not achieve the same set of goals, it wouldn't necessarily be bad.
I guess I'm suggesting that the most shallow waveguide is a flat baffle. Knowing what we know now...well, I for one will never build a conventional speaker the same way as I used to. |
#3 | |
Custom Title
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#4 |
Ah yes. I was thinking more a 180 degree design. A dome tweeter could reach low to be met by a very small woofer (that would only be used to around the Schroeder frequency) that was mounted on a wide baffle or even soffit/wall/corner mounted. Or even yet, ditch the tweeter, use a very small full range woofer on same wide baffle for a little pseudo narrow directivity at the top end.
#5 | |
On that note, does something like the Salk Soundscape (RAAL crossed to an 3" accuton) seem like it has matching directivity index? Last edited by RockLeeEV; 16th May 2011 at 08:38 PM. |
#6 |
or what about a 4-5" woofer mated to a 2" cone/inverted dome tweeter
Im the guy that speaks in haste, and makes ill conceived theories, thinks math is a necessary evil, but i know something.Sometimes it bugs me, then i then i realise that theres 10 more just the same.So i guess Mulder was right. We are not alone. |
| Free: Focused electrostat arrays | Ang | Swap Meet | 11 | 2nd May 2010 11:35 PM |
| 4 driver focused array | norman bates | Full Range | 28 | 2nd January 2010 08:44 PM |
| Focused (concave) vs. linear line array | GuyPanico | Multi-Way | 15 | 21st June 2006 08:04 AM |
| Page generated in 0.10509 seconds (76.66% PHP - 23.34% MySQL) with 10 queries |
