Old 14th May 2011, 02:44 AM   #1
Default midbass and midrange speaker to go with my tapped horn
Finally building some tapped horn sub but need drivers for midrange and midbass.
Looking for a eminence 12 inch driver to play midbass from 100hz to 400hz.
Looking for a eminence 10 inch driver to play midrange from 400hz and up.
THANKS
Old 14th May 2011, 11:48 AM   #2
Josephjcole's Avatar
100Hz to 400Hz is a pretty small range for a 12" eminence. I do have an eminence delta 12lf which I use up to around 400Hz. It seems to do the job quite well...
Joe
Old 14th May 2011, 04:21 PM   #3
Joe
Thanks joe
Old 20th May 2011, 01:59 PM   #4
epa is offline epa  Netherlands
im having trouble to get extension above 300 hz.
what are you thinking size wise.?
how are you wood skilz?
we need to go exponential,not paralel
Old 20th May 2011, 02:29 PM   #5
Size 30x30x30
Wood skill 1 out of 5
Old 20th May 2011, 02:37 PM   #6
Originally Posted by kornnylike View Post
Size 30x30x30
you mean inches i gues
can we put 2 in 1 box or 4 sepperate cabs?
what are your subs?
Old 20th May 2011, 02:40 PM   #7
4 seperate cab
the 30x30x30 can be smaller
Yes I mean inches
Old 21st May 2011, 09:42 AM   #8
can you give some info of the rest of the system
you wil stack 2 kicks on your subs?
the le value is high,so its difficult to get the upper freq.
what wil u be using above the kicks?
whats the freq range of your subs?
Old 21st May 2011, 12:44 PM   #9
ckeck your PM
Old 22nd May 2011, 09:56 AM   #10
can you bild this?
Speaker for a Tapped horn subwoofer. Jaime Subwoofers 0 25th November 2010 12:29 AM
tapped horn for midbass soundhead Subwoofers 28 26th June 2010 01:49 PM
Is this a good speaker for tapped horn soundhead Subwoofers 1 27th December 2009 10:53 PM
Is this a good speaker for tapped horn soundhead Subwoofers 0 27th December 2009 04:35 PM
Tapped Horn for Midrange Patrick Bateman Full Range 2 30th October 2006 02:09 PM
Page generated in 0.09655 seconds (77.21% PHP - 22.79% MySQL) with 10 queries
