Quick baffle step correction question. - Page 5 - diyAudio
Old 14th May 2011, 09:41 AM   #41
picowallspeaker's Avatar
I suspect the forum is a lazyness -inductor
get it on !!!
Old 14th May 2011, 10:07 AM   #42
AllenB is offline AllenB  Australia
Originally Posted by digits View Post
So it will only be temporary speakers for learning
pico is correct but it might not be that bad.
Old 14th May 2011, 11:55 AM   #43
digits's Avatar
Lol, at the moment those woofers are just slapped into a box, that blew a driver, with whatever tweeter and crossover was in there... ANYTHING should sound better, Its just that wood and parts are not cheap (even when its free), so I'd like some very concrete working points before I start
Old 14th May 2011, 12:07 PM   #44
It's only my opinion but even though they go against some of the established rules of thumb, I think they'll sound fine in that box. I'd be more concerned at whether the woofers sound OK around the 2kHz mark because you may be cutting it fine to choose a crossover point.
Old 14th May 2011, 12:23 PM   #45
digits's Avatar
Well, they are not horrible sounding at the moment, just a bit shy in the mids.
Not perfect, but you can buy 10 drivers for the price of a set of my scanspeaks.
Old 14th May 2011, 12:58 PM   #46
Just checking, have you stuffed the box and are you using a tweeter at the moment?
Old 13th October 2011, 05:14 AM   #47
alspe is offline alspe  Finland
Is baffle step compensation about same that Lpad for tweeter? Just with different corner frequency.
Can someone link here the most useful white papers for passive crossovers. (this I've found Passive Crossover Network Design)
Have to found something to read and understand, escpecially cases where lowpass and BSC are done with same components in circuit. usually they are done like that?
question about baffle step correction kennyhorn Full Range 2 20th November 2010 06:43 PM
Modeling a Baffle Step Correction Circuit Seadweller Full Range 4 28th December 2007 09:51 PM
Baffle step correction circuit - how to design? mr_push_pull Multi-Way 28 9th November 2004 08:27 PM
Baffle Step Correction: ignored in commercial systems teodorom Multi-Way 15 9th June 2004 08:32 PM
baffle step correction and bypassing it xcortes Multi-Way 11 9th May 2004 04:14 PM
Copyright 1999-2017 diyAudio
