Old 11th May 2011, 10:07 PM   #1
Default Need help understanding wiring diagram
I'm trying to build a simple jig to measure some drivers. I read about it here. AudioBlog: A simple loudspeaker measurement jig for ARTA
I have a Sound Blaster card in my PC with 1 line in, and multiple line out jacks. This seems to be the way most sound cards are implemented. I'm assuming that I'm supposed to hook up my single Line In connector to this jig. But I have no idea how. Can some one straighten me out?
Old 11th May 2011, 10:25 PM   #2
I just realized that the Line In cable has 3 wires. One for ground, and one each for left and right. Ground is common, Left goes to one of the circuits, and Right goes to the other. Is that correct?
Old 12th May 2011, 08:26 AM   #3
AllenB is offline AllenB  Australia
That is correct, and use the left output from the green socket when otherwise not specified. One of the inputs measures the speaker and the other measures the signal driving it and the difference is recorded. This works around imperfections in the amp.
Understanding the Zaph Waveguide TMM crossover diagram mikan Multi-Way 35 4th May 2009 05:44 PM
Please check my wiring diagram... eisenhower Multi-Way 13 16th October 2006 07:30 PM
Subwoofer Wiring Diagram boris333 Subwoofers 10 4th October 2005 11:16 PM
can i use this wiring diagram mitchell Car Audio 3 23rd August 2004 08:50 PM
Page generated in 0.05296 seconds (79.21% PHP - 20.79% MySQL) with 11 queries
