Hi, do you people think this horn will work with my 206e or 206En
PiSpeakers Forum - Horn Basics - Wayne Parham, April 12, 2004 at 02:01:43. Thanks for your advice in advance. Regards |
#2 |
Interesting! Just stumbled here while thinking about same thing!
Hope someone will point us. |
#3 |
Forget it, the drivers are unsuitable for horn use.
Brgds Lars |
#4 |
I'm on the cell phone at the moment and can not search this site. Last night I saw Le Cleachorn thread somewhere here with fe206e with front horn and K-horn bas bin.
#5 | |
something related: Welborne Labs - As a user of FE206E's in Azurahorns - Triodeuser, January 29, 2004 at 05:38:38 Le Kleachorn (with apologies to Jmmlc) High Efficiency Speaker Asylum - Re: large horn - waissin, October 15, 2003 at 22:16:16 Large Front Loaded Horn Speaker [Archive] - Stereo Net Australia Best regards , Jean-Michel Le Cléac'h |
#6 |
Thank you! Honered to see mr. Le Cleac'h himself wrote an answer to my question. The second link is one I saw. Tonight when home will read other links. Cheers!
Edit: Minhaj, sorry for hijack! I'm just curious about same or similar idea. Last edited by zerowaf; 16th May 2011 at 01:06 PM. |
#7 |
After the discouraging sim of the 206e I also tried 206en and that looked a lot, lot, lot better. Question is how much the whizzer-cone will contribute to hf-response? Note it needs a 3dm3 backchamber to keep lf-response OK. Will work with open back if you can accept a higher Fc.
Sim is with a full Le'Cleach 200Hz, T=0,8 and 2,55:1 compression. 2:1 might be OK too.
Brgds Lars Last edited by revintage; 16th May 2011 at 01:29 PM. |
#8 |
IIRC the whizzer cone kicks in at 3K or so, which is why the data sheet response becomes so ragged at that point.
#9 |
The rising response in the upper register might help a lot. I guess the treble response will also be better than the sim due to direct radiation. Still a tweeter might be added due to beaming. Jean-Michel can probably predict this.
No other sims than those with full LC shows a close to flat respons on 0-20 degree axis. The others like Sph and Tx shows rising response. Anyway dump the idea of the conical Pispeakers horn.
Brgds Lars Last edited by revintage; 16th May 2011 at 01:45 PM. |
#10 |
Thnx, Lars! I begining to Understand what u mean now.
| My Ultimate Fostex FE206E Horn! | brsanko | Full Range | 33 | 23rd March 2010 01:49 PM |
| Fostex FE206E front horn? | weikertball | Full Range | 9 | 18th February 2010 10:57 PM |
| Fostex FE206E BL horn speakers | sarrisk | Full Range | 7 | 31st August 2008 03:04 PM |
| Backloaded horn with Fostex FE206E | Arie | Full Range | 1 | 9th February 2008 01:28 PM |
| FE206E psuedo front horn? | bbaker6212 | Full Range | 2 | 20th May 2006 10:17 AM |
| Page generated in 0.11148 seconds (80.73% PHP - 19.27% MySQL) with 11 queries |
