Old 11th May 2011, 09:31 AM   #1
Naidu is offline Naidu  Singapore
Default Tannoy HPD 385/385A
Would like to seek help to identify if the drive units are 385 or 385A. Baught the pair some months back with the crossovers but without the boxes. The serial nos are 41/212157 and 210453 and they have 8 mounting holes each. Based on information available these should be the 385s, however recently when I opened up the crossovers to upgrade the parts, it appears that these are for the 385A. Thanks for any comments
Nara
Old 11th May 2011, 04:23 PM   #2
Face is offline Face  United States
Face's Avatar
The crossovers between the two are very similar and may work with either model. It's also possible someone swapped the crossover units out somewhere down the line(they are 30+ years old). 8 mounting holes should make the driver itself a 385.
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen
Tannoy HPD Surrounds rhw4 Multi-Way 5 21st July 2008 01:24 PM
Improving Tannoy HPD-385 Arden SQ? Face Multi-Way 11 23rd March 2008 06:30 PM
Tannoy HPD Dual Concentric 15inch JRKO Swap Meet 6 22nd December 2007 02:18 PM
Tannnoy Berkeley HPD 385A JRKO Swap Meet 0 22nd August 2007 05:25 PM
FS: Tannoy HPD 385A 15" Gold Monitors Brett Swap Meet 0 29th January 2002 06:24 AM
Page generated in 0.06843 seconds (69.91% PHP - 30.09% MySQL) with 10 queries
