Old 9th May 2011, 11:52 PM   #1
Default 2-way speaker with an 8 inch?? Your input are more than welcome..
Hi guys,
First of I can say that I’m a noob. Still I would like to build a 2 way speaker with a 7’’ or 8’’ from the list under. My first criteria, unfortunately, is the budget, but I would like to have a little more bass then a 6 ½’’. That’s why I choose an 8 inch(vented system). I do not need 120dB, but listen to rock, jazz, r&b, even metal sometime and like to crank it sometime. Floor standing
http://www.solen.ca/pdf/dayton/RS225S-8.pdf
http://www.solen.ca/pdf/dayton/RS225-8.pdf
http://www.solen.ca/pdf/dayton/RS225-4.pdf
http://www.solen.ca/pdf/hivi/m8a.pdf
http://www.solen.ca/pdf/fountek/fw168.pdf
http://www.solen.ca/pdf/silver/w20rc3808.pdf
http://www.solen.ca/pdf/vifa/pl18wo0904.pdf
I would like to keep the crossover simple, of course.
Have a good radiation profile.
The living room is about 15’ per 15’.
Don’t know which tweeter to use. Probably a ring tweeter from Vifa.
Bottom line, 50 to 60$ for the woofer, 30 to 40$ for the tweeter.
Thank you against.
Old 10th May 2011, 12:25 AM   #2
This might fit the bill
Parts Express DIY Project
It is only rarely that one can see in a little boy the promise of a man, but one can almost always see in a little girl the threat of a woman. ~Alexandre Dumas
Old 10th May 2011, 12:48 AM   #3
stoc005 is offline stoc005  United States
stoc005's Avatar
How about an AUDAX HM210C0? See Madisound Speaker Components | Loudspeaker drivers and speaker parts for loudspeaker builders. Use a good tweeter that can be crossed over at 2K or less to avoid beaming.
I have my first DIY speaker system that uses a HM210G0 (paper cone) and a SEAS 25TAC/D chambered tweeter that is XO @ 1800, second order passive. It rocks! Ported box and lots of good low bass. The SEAS tweeter is/was cheap and could handle the low XO frequency. Both drivers are no longer available since this was designed/built 5 years ago. Any way, my goal was for more bass than a JBL 6.5 2-way I usually used. Mission accomplished with the Audax. Nice drivers but no longer cheap. Mine cost 56.00 back then. Audax has almost left the DIY scene with only a few drivers available.
Be sure to add BSC (baffle step correction) to your crossover if you plan to use your speaker NOT against the wall. I didn't do it and I wish sometimes I had added it so I could place them a bit away from the wall.
Sadly the Audax does not meet your cost goal.
Old 10th May 2011, 02:54 AM   #4
Hi Steviedon,
I'm afraid that I will never found a tweeter able to go that low without alot of distortion. The tweeter seem pretty interesting. Also, I live 2 corner from Solen and I dont want to pay for taxe and duty and all the thing that make a small project cost the double.
Ty
Old 10th May 2011, 02:59 AM   #5
The Audax is a killer in spec but kill my wallet to. Do you have some suggestion regarding the woofer I post earlier?
Old 10th May 2011, 04:36 AM   #6
stoc005's Avatar
Peerless 830869 from Part Express $63.22
Fountek is OK....but small.
Avoid metal cones if possible. I like paper.
RS225S-8 is OK if you use a deep slope XO to avoid the crap above 2K.
The rest...pass
Consider going to electronic XO and 4 power amps if your budget can stand it.
Go to Zaph|Audio He does a good job of evaluating 6.5-7 and 8 in. drivers.
Consider one of his designs too. Some can be built rather cheaply and many have been successfully built. Ask around on this forum for opinions.
Have you priced out what good components for crossovers cost? Air core inductors and quality caps are not cheap. They can cost as much as a good driver.
Old 10th May 2011, 05:06 AM   #7
Check out my Vifa PL18
AmpsLab.com
Old 10th May 2011, 05:17 AM   #8
andy2 is offline andy2  United States
How about this? Humble Homemade Hifi
Old 10th May 2011, 05:40 AM   #9
frugal-phile(tm)
planet10's Avatar
Originally Posted by Popensky View Post
silver flute w20rc3808
...I would like to keep the crossover simple, of course.
Let me suggest something a bit different. I like the Silver Flute. So do Ed Schilling and Steve Deckert. It is fairly efficient so mating it with a mid-tweeter leaves not a whole lot of choice. The #1 candidate is a nice piece thou.
Mate the Silver Flute with the Fostex FE83En at about the baffle step frequency. At these frequecies a simple 1st order series XO will likely do the job.
From Madisound just under $70 a side, which is less than budget, but XO parts are going to be pricier.
Due to the low XO, with reasonable close placement the drivers will effectively be coincident, and give a very good radiation profile.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th May 2011, 11:08 AM   #10
DavidL is offline DavidL  United States
DavidL's Avatar
http://classic-web.archive.org/web/20071207183643/www.wadsnet.com/~dtenney/dayton_8MTM.htm
Dual 8 MTM floor stander
2 inch speaker T & S parameters jwatts Multi-Way 1 16th December 2011 02:53 PM
3-5 inch driver for HT use....input needed. steviedon Full Range 73 9th December 2010 05:53 PM
My 8-inch open baffle speaker dabbler Multi-Way 19 28th September 2010 11:15 AM
12-inch wooden horn speaker gxcnabin Multi-Way 42 21st July 2010 07:26 PM
looking for a good 15 inch speaker soundhead Subwoofers 4 11th February 2010 01:29 AM
Page generated in 0.11564 seconds (84.64% PHP - 15.36% MySQL) with 10 queries
