Old 9th May 2011, 03:31 PM   #1
Default Port volume
Hi all,
When calculating the amount of internal volume displaced by a port, is the port to be seen as a solid object inside the enlcosure or is it only the wall thickness of the port that counts towards displacing internal volume. I assume its the former, is that correct?
Thanks in advance.
Old 9th May 2011, 03:56 PM   #2
Originally Posted by lucadelcarlo View Post
Hi all,
Thanks in advance.
The former.
In a small cabinet with a very large port the lines between which is which can become blurred.
Old 10th May 2011, 04:03 PM   #3
gedlee is offline gedlee  United States
Any air in the box that actually moves is not part of the box as far as its compliance is concerned.
Old 10th May 2011, 04:32 PM   #4
badman is offline badman  United States
Custom Title
badman's Avatar
Would you consider the air near the internal port termination to be "moving"? Should people be subtracting MORE than the vent volume?
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 10th May 2011, 05:26 PM   #5
Yes, just as the port acts longer than it actually is, it takes up more space than it actually does.
Old 10th May 2011, 05:41 PM   #6
Earl,
A slotted port, that is a port using the side of a cabinet as one of it's sides, "acts longer" (tunes fB lower) than a circular duct located away from the side walls, and occupies (takes up) less cabinet space than a circular duct providing the same Fb.
What type of port "acts longer than it actually is, and takes up more space than it actually does" ?
Art Welter
Old 10th May 2011, 06:41 PM   #7
Originally Posted by weltersys View Post
Earl,
Art Welter
I'm not sure that this is actually true, to a first order the port shape has nothing to do with the situtation. The acoustic mass depends on length/area with an end correction term that loosely depends on the shape. But if the shapes are similar and then there is still the length/area ratio that determines the port volume for a given box tuning, and hence it can be anything. Where and how it is situated in the enclosure is not a factor. Of course the lower the port volume the more losses there are so this becomes self defeating.
Reflex PA Sub - Volume and Port Design? Xoc1 Subwoofers 3 26th April 2010 01:10 PM
2 Woofers = 2 x Volume = What Port? sdclc126 Multi-Way 21 16th January 2008 07:53 PM
Round VS Shelf port volume Mick M Multi-Way 1 20th November 2004 05:44 AM
Need Volume And Port Size For Norh 9.0 sardonx Multi-Way 0 1st August 2004 02:44 AM
Question about port volume dveous Multi-Way 3 7th July 2004 07:24 PM
Page generated in 0.57543 seconds (12.43% PHP - 87.57% MySQL) with 10 queries
