Old 8th May 2011, 09:52 PM   #1
trondareo's Avatar
Default tannoy 607 - speaker elements - use in a project
I was just given a pair of Tannoy 607 SIXES by a neighbor who on the verge of trashing them. they are in good condition in original box.
Does anyone know the specs for the elements in them, or have ideas for other use of the elements?
I´m doing stuff at http://taooftubes.blogspot.com/
Old 9th May 2011, 01:22 PM   #2
trondareo's Avatar
Bump!
I am thinking of using the elements from a pair of Tannoy 607 Sixes for something fun.
transmission line, TQWT, omnipolar etc. any suggestions?
Drive units 25 mm aluminium dome tweeter
8" bass unit
Recommended amplifier power/channel 10 - 100 watts
Peak power/channel 175 watts
Nominal impedance 8 ohm (minimum 6 ohm)
Sensitivity (2.83 V @ 1 mtr)88 dB
Frequency response +/- 3dB 50Hz-30kHz
Crossover frequency 3 kHz
Crossover type 1st order low pass
1st order high pass
Terminals Bi-wired
System type ducted port
Internal volume 17.0 litre
I have not found any further secs on the elements.
Tannoy V8 crossover project doug20 Multi-Way 14 30th July 2011 11:42 AM
Designing Own Speaker Elements Ultima Thule Multi-Way 54 10th March 2010 03:19 PM
Tannoy 609 compared with Tannoy 615 photomusicfreak Multi-Way 4 27th November 2008 10:27 PM
Focal elements Space489 Multi-Way 0 22nd December 2004 12:17 PM
Page generated in 0.05666 seconds (68.93% PHP - 31.07% MySQL) with 10 queries
