Guys,
Lately I got 4 2510 10" and would love to make couple Onken bass box for my future project. My intention is to put 2 drivers in one box and aim at highest db as possible so to cope with my 2A3 and 300B amps. I really would love to match it with a mid horn and a tweeter. I've been searching all over the forum and seems not too many Onken box with 10" driver. I finally come with a calculation posted by GM and have the following result. I know the result doesn't look right and I have to admit that I'm not good on math. Please take a look at the attachment and I'd appreciate any ideas provided. BR Albert |
#2 |
ONKEN CALCULATOR by Cyr-Marc Debien 2000 © cdebien@cmaisonneuve.qc.ca
After original research from M. Eijiro Koïzumi and Jacques Mahul and Jean Hiraga calculations. Koïzumi factor K= 1.57 K= 83.210 Hz You can modify the RED value. The Green Value are calculated by the software. In many case it's for validation. TS parameters Fs 53.000 Hz driver frequency resonnance Re 5.060 ohms dc resistance of driver Qms 5.760 mechanical Q of the driver Qes 0.450 electrical Q of the driver Qts 0.417 total Q of driver at Fs calculated by the software Mms/d 31.000 gr total cone assembly mass Sd 3.501E+00 m^2 effective radiation area of the driver cone Rg 0.300 ohms total components resistance (xover coil, terminal, wire, amplifier, etc.) Cms 2.91E-04 driver suspension compliance calculated by the software Vas 499309.099 litres air volume driver compliance calculated by the software Vas*Qts2 96774.541 calculated by the software n = 6.340 (best 5.7) Onken alignment (best alignment = 5.7, Onken alignment = 6.34) note : you can play with the n factor to maintain the L' vent under 30 cm but try to don't used a excessive value because you don' t respect the Onken approach Box and system response F-3 47.812 Hz box cutoff frequency at -3dB Fb 46.951 Hz box cutoff frequency Cab 43825.042 acoustical box compliance 0.477 Map 0.003 acoustical mass box 0.440 S vent 304.000 cm^2 this value is calculated by the vent dimension section 0.000 nO 159.243 Vas*Qts2’ 96774.541 dB 1w/1m 133.520 dB total efficiency of the system including Rg Vent lenght L vent 0.006 cm effective lenght vent L’ vent -9.732 cm corrected effective vent lenght (use this lenght in your vent calculation) note : If the L' vent is over 35 cm, your driver is not suitable for the Onken speaker application Vent dimension (habitually an Onken speaker have a S vent equal or -15 % smaller to the driver Sd) Width 4.000 cm indicate the width of one vent Height 9.500 cm indicate the height of one vent Quantity 8.000 indicate the number of vent you can use (Onken speaker have 6 or 8 identical vent) S vent 304.000 cm^2 total vent area (try to obtain a S vent equal or maximum 15% less to the Sd) Vent volume -2.959 litres total volume occupied by all vent in the box Total Box Volume Vb 613550.590 litres total internal volume of the box Vb Total 613547.631 litres total internal volume of the box plus the required volume for the vent I filled in all numbers I know on the red box and come up with the above numbers. |
#3 |
According to my spreadsheet based on the "Petite Onken" article you get for two drivers in one box:
Vb=117dm3, F3=50,1Hz, Sev=700cm2/L=53cm. Unfortunately this isn´t the optimal Onken, as F3 is to high and L is to long. Using the pair in a 3m long, 35Hz basshorn and 1075dm3 volume sims very well though. Over 115dB sensitivity!
Brgds Lars Last edited by revintage; 7th May 2011 at 07:03 AM. |
#4 |
Lars,
Thanks for the input, but I don't know what is a basshorn look like. Can you send me a link I could take a look at ??? Albert |
#6 |
#7 |
Using your data on the Onken spreadsheet and using the two speakers in parallel
I get the following, provided I have entered the data correctly: jamikl |
#8 | |
Thanks for the help. Now I got 2 box volume. Which one I should go for, the 149.337 litres/or 165.781 litres. Also I have 8 vent, 4.25 x 15 cm each. How deep ?? Albert |
#9 |
Let say 150 litres is the number. I come up with the following numbers upon 3/4" for vent dividers, 24.5" H 21" W 18" D and the vents volume also include into the size, or I have to exclude the vents from the box size
Albert Last edited by albertli; 8th May 2011 at 02:35 PM. Reason: picture to attach |
#10 |
I draw the diagram as attached.
| Eminence DeltaLite II 2510 for sale or trade | aptquark | Swap Meet | 4 | 29th September 2011 07:00 AM |
| VIFA P13WH-10-04 5" Mid-Bass Drivers | HampyCapper | Swap Meet | 2 | 30th April 2010 08:36 AM |
| Onken for 10" or 12" drivers. | maal1605 | Multi-Way | 1 | 29th November 2008 01:52 PM |
| Box Info For DELTALITE 2510 | Zero Cool | Multi-Way | 3 | 29th March 2005 07:32 AM |
| Eminence bass drivers | andybrook | Car Audio | 3 | 25th February 2004 10:47 PM |
| Page generated in 0.12446 seconds (81.89% PHP - 18.11% MySQL) with 11 queries |
