Onken bass box with 2 Eminence Deltalite ll 2510 10" bass drivers - Page 3 - diyAudio
Old 9th May 2011, 04:58 AM   #21
digits's Avatar
Originally Posted by GM View Post
Greets!
For the math challenged, he further complicated it by using scientific notation and m^2 for 'Sd' instead of the more common cm^2, which is where you messed up, so one must have a conversion chart or program such as 'Convert' to help folks like us.GM
Google can do nearly all your conversions these days.
simply type 10 cubed cm in cubed m and it will kick out the answer, I just used 10 as an example...
Old 9th May 2011, 02:33 PM   #22
GM is online now GM  United States
GM's Avatar
Originally Posted by albertli View Post
All my amps are 8 ohm.
I thought I'd put them up for the other project.
You're welcome!
Good plan with these drivers. For future reference though................
I assume this is just the nominal tap rating, so isn't what we're referring to: Amplifier Output Impedance
This doesn't rule out their output impedance being this high or even higher, I've seen as high as 20 ohms back when horn drivers were typically 16 ohms, so there's the matter of driver selection when driven by a high output impedance which make the 2510 a poor choice if not in a TL or similar loading since it already has a Qts on the high side for vented box loading: Highly Reactive Loads and SET Amplifiers
Regardless, to fully realize the inherent potential of all SET tube and OTL amps, a loudspeaker of 14 ohms or greater is mandatory to maximize power conversion efficiency. Anything less involves a huge compromise, so most drivers will need to be wired in series.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th May 2011, 03:03 PM   #23
Hey Albert,
An idea could be to go active and run your bass-sytem with SS and use your 300B/2A3 for mid and high. By doing it this way you can also remove the filter-components (coils) that add resistance.
Old 9th May 2011, 03:13 PM   #24
GM's Avatar
Originally Posted by jamikl View Post
ICMD is the one I have but I thought you made it available.
You thought right , I uploaded CMD's to e-snips back in '08 after folks complained about all the original links being dead.
GM
Old 9th May 2011, 05:09 PM   #25
albertli's Avatar
Originally Posted by revintage View Post
Hey Albert,
Lars,
Active might be a good idea, but my intention is to run passive for a three way system. I thought I better go with the tradition route with 414 since infos are easily available.
Albert
Old 9th May 2011, 06:28 PM   #26
Hey,
IŽve got a small stash of 414-8A(must be -A or -B) and earlier ran "Petite Onken". I am now working on a midbass-horn for them. With PT best results where achieved with active. Whatever they sound great.
Take a look in the spreadsheet what happens when adding external resistance. Your tube amps will not do. But adding 0,2ohm and running SS will not harm.
Old 10th May 2011, 04:57 AM   #27
GM's Avatar
Good to know, thanks! It doesn't seem to work quite the same for me though WRT to in. 350.1 cm^2 in m^2 converted it to milliliters, but when to was used it did the conversion correctly. For now though, I think I'll stick to using Convert.
GM
Old 10th May 2011, 06:37 AM   #28
Hey guys,
IŽve taken the liberty to adjust the spreadsheet to take Sd in cm^2. Also removed one unnecessary decimal.
Actually the original Onken calculations from the Petite Onken article in LŽAudiophile " only needs Vas, Qts and Fs or Mms, Qts, Sd and Fs. One might then add Re to make it possible to input Rg.
Maybe I should reduce the spreadsheet to make it less confusing?
http://www.revintage.se/ONKENcm3.xls
Old 10th May 2011, 10:17 AM   #29
This is a somewhat easier to read spreadsheet. Qms and Qes are needed for adding Rg. The starting figures are for "Petite Onken" with Altec 414-8A/B.
http://www.revintage.se/ONKENcm3414.xls
Old 10th May 2011, 02:34 PM   #30
GM's Avatar
I actually did this right after it was published and suggested it in a pm, but got no response IIRC. At the time, JMMLC was helping me update mine when time permitted after Guy Pelletier [another French Canadian] I had met on one of the mailing lists pointed out that my formulas didn't match the original's; but the day I went on-line to announce I had a proper Onken calculator available, I found CMB's had beat me to it, so didn't bother since I didn't want to 'steal his thunder'.
Apparently he considered my suggestion rude/whatever because the next time I posted on one his threads he got really rude/cross with me for no apparent reason, basically telling me he wasn't interested in anything I had to say IIRC.
I started to upload it or mine when the old links went dead and again the other day, but having never seen the original document[s], didn't know if his was 'by the book' or JMMLC's corrections to mine which only uses Vas, Fs, Qts and the driver's effective radius. There's some other detail differences, but without the original document[s] I've no way to know which is the most correct.
Not that I care though as I've periodically noted along with the 'why' and all things considered, wished I'd gone ahead and posted mine anyway to give folks another option.
Regardless, if I wanted a fine performing cab with the Onken 'look' for dual 2510s, I'd make the vents full size and as long as required and damp the cabs to 'taste' same as a TL, though wouldn't drive them with a high output impedance since it will make the them relatively to outright huge depending on how high it is.
GM
Eminence DeltaLite II 2510 for sale or trade aptquark Swap Meet 4 29th September 2011 07:00 AM
VIFA P13WH-10-04 5" Mid-Bass Drivers HampyCapper Swap Meet 2 30th April 2010 08:36 AM
Onken for 10" or 12" drivers. maal1605 Multi-Way 1 29th November 2008 01:52 PM
Box Info For DELTALITE 2510 Zero Cool Multi-Way 3 29th March 2005 07:32 AM
Eminence bass drivers andybrook Car Audio 3 25th February 2004 10:47 PM
Copyright ©1999-2017 diyAudio
