Old 5th May 2011, 07:25 AM   #1
Default Whats wrong, or right with this picture??
Hello all,
Looking to build the attached design, based off the Tony Gee Nebular.
Will be running nearfield in a small office (hence the need to push into the corners. Will be running off a PP EL84 amp in about 6 months, and right now, off a 20watt SS D class.
Should the driver be mid way between the passive radiators for equal pressure, or as its 'sealed' does this matter?
Whats right or wrong with the current design? Internal volume is 12 litres.
Thanks in advance, Malcolm
Old 5th May 2011, 08:59 AM   #2
OK, so just found one thing wrong!!
Can I mount a passive radiator down-firing?
The PR should never be down-firing, the high Mms will cause the diaphragm to be displaced downward immediately. The spiders will eventually be stretched permanently by this treatment, and the unit will need to be rebuilt.
Source: http://www.aespeakers.com
Old 5th May 2011, 01:12 PM   #3
AllenB is offline AllenB  Australia
Yes, it does seem a little unusual. Have you looked around at other designs?
Old 5th May 2011, 03:50 PM   #4
Speakerholic
Cal Weldon's Avatar
Yes I would be concerned about an up or down firing drone.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 5th May 2011, 04:17 PM   #5
18Hurts is offline 18Hurts  United States
The passives are quite heavy,
My 18" passive has a cone + weights for tuning bending the scales at 1,050 grams. They must be mounted "on edge" to prevent sagging of the suspension from all that weight. It also has a bad effect on tuning since it has to fight gravity and lowers available Xmax.
Old 5th May 2011, 05:30 PM   #6
in one direction gravity helps the cone, in the otherone is works against it.
it just makes a whole lot of unpredictable distorsion in tuning.
Whats wrong with the picture? K-amps Pass Labs 19 19th November 2006 03:12 PM
What's wrong with this picture? EchoWars Solid State 2 8th June 2004 08:40 AM
Whats Wrong with My Chips! Marvellous Chip Amps 5 29th April 2004 12:16 PM
Page generated in 0.08385 seconds (77.27% PHP - 22.73% MySQL) with 11 queries
