For example Sonus Faber use that faux leather finish, Burmester use a shiny metal cover, Magico do something similar in a matt metal finish, Rockport use a felt around the units..
What the best material on a baffle? hard/soft etc, does it make any real difference? |
#2 |
I've seen all sorts of things
My 1990's era Infinities have a smooth waveguide plate that mounts over the entire front bezel with 4" midranges and 1" dome tweeter so the front bezel is very smooth. The side mounted 8" woofer does not use a waveguide since it is used under 300 Hz. Rounded edges prevent diffraction of sound so a round over bit on the speaker bezel helps. I've seen felt/foam used on speakers from JBLs to RAAL ribbons so it probably does something. One of my planned tweaks is to use wool felt rings to cover my midwoofer mounting bolts in an attempt to prevent diffraction. Might not work but felt is cheap and the grill is going to hide it. I always wondered if you surface mount the drivers then cover the face of the bezel with 1/2" wool felt--would that achieve the same thing? |
#3 |
Those RAAL foam things look a right dog's dinner, even if they are somehow an intentional part of the design.
| Front baffle materials (cork ?) | 00940 | Multi-Way | 8 | 21st March 2010 03:47 AM |
| Are crimp terminal alter performance? | kzeprf22 | Solid State | 37 | 8th September 2009 11:54 PM |
| Did you know that the tightness of the jacket materials could change the sound? | commstech | Parts | 26 | 14th November 2004 10:36 AM |
| Different case materials=different sound...ummm...explain. | Doovieman | Chip Amps | 89 | 22nd September 2003 07:33 PM |
| Finish for loudspeaker baffle exterior | Flames | Multi-Way | 2 | 20th February 2003 07:09 PM |
| Page generated in 0.07129 seconds (74.75% PHP - 25.25% MySQL) with 10 queries |
